I made a logo for someone but we made a mistake in the illustration itself so I opened the indesign file but I can't seem to edit or delete any of the paths or anchor points on the logo
[Moved from the non-technical Lounge Forum to the specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
You haven't said what you have tried that doesn't work, so some questions:
Was the logo created in InDesign?
Or was it created in Illustrator and placed into InDesign?
Are you using the Direct Selection tool?
Did you deselect and then try to select an anchor point?
Is the layer locked?
Is the object locked?
Is it on a master page?
Who created the logo?
What happens when you try to edit it?
Screen shots help!
Screen shots help!
Nevermind I figured it out thanks for your help though
Thanks for enlightening us. What was the solution?
The logo may have been created in Illustrator and placed into InDesign. If the logo was placed into InDesign it would not be directly editable.
If you open the Links panel, do you see a link to the logo? If so, you can open the link in Illustrator to edit it.
Sounds like the logo WAS created in Illustrator, so that's where you want to edit it.
Hope this helps!
All good figured it out thanks
Please mark an answer as correct, so people stop answering.
