Hello,
Does anyone know how to get rid of the appearance of a ripple effect in the gradient shown in the link above?
It only shows up after I import into Premier Pro.
I tried adding a blur but it didn't help.
Any suggestions greatly appreciated.
Thank you!
it's called banding.
try working in 16bit in Ae (in Ae's project settings), and export a 10 bit cineform go pro from Ae. (Quicktime->GoPro Cineform. under video output in the output module settings change it to trillions of colors). if that does not work, try adding a little grain on your graphics (with an adjustment layer-> add an "add grain" effect, adjust the parameters)
Thank you so much for these suggestions. This was very helpful and made a big difference. Thanks again!
You're Welcome. thanks for the feedback and glad it worked for you.
