Hi everyone,
I have been handed a project and I have been asked to make it work when it's published. At the moment it's working in the test environment, but when published the linked FLAs fail to load. It works just fine in previous versions of Flash, but with Animate, it fails to load.
My knowledge of Animate is limited, and I don't know ActionScript. Any direction you can provide will be beneficial.
I have done some research in various forums and my initial thoughts are it could be a URL (the reference to the XML file in the portfolio.fla) not resolving:
https://stackoverflow.com/questions/12645556/flash-builder-urlrequest-local-path-not-resolving
The debugger is throwing this error when the portClick event is clicked:
Error #2044: Unhandled IOErrorEvent:. text=Error #2036: Load Never Completed.
I'm not even sure if the project is ActionScript 2 or 3.
Thanks in advance for your help. Here is the shared content from my Google Account:
The local location has to be set as a trusted location. Go to this page:
Adobe - Flash Player : Settings Manager - Global Security Settings panel
and click the Edit Locations drop down menu, Add Location, and Browse for Folder. Find your 'Artistic' folder and add it. Then your videos should work.
Another solution for local playback is to go into Publish Settings and check the Projector option. You can do Mac and Windows. The Mac projector will play the files ok, even if they are in a new untrusted
...Copy link to clipboard
Your files seem to be ok. It is AS3, but the HTML has an old way of detecting the Flash plugin, and so won't load the content.
What is an example set of actions that will show a problem? I could watch the videos ok by opening index.swf in Flash Player.
If I publish the project and open the index.html file I can't get the content to display in linked swf files. I have tried in Safari, Chome and Firefox
I'm running the debug Flash Player, and I see a lot of errors when I try a publish of the index.html. I'm trying to see what's causing the errors.
It seems that the files run ok when they are online, just not locally. Try this link and tell me if anything isn't working:
In the publish settings HTML Wrapper section I had to check the "Detect Flash Version" box in order for the page to load ok. And of course in Safari I had to click the button to give permission for the plugin to work.
Hi Colin, that's right. You're link works perfectly fine, but locally this is what I get when I click on the portfolio button:
And here are my publish settings:
I appreciate you taking a look at this for me. Thanks a bunch!
Another solution for local playback is to go into Publish Settings and check the Projector option. You can do Mac and Windows. The Mac projector will play the files ok, even if they are in a new untrusted folder.
Thanks a bunch, Colin. Adding the desktop as a trusted location did the trick. I really appreciate your help. So will the teacher, and the students that I was assisting. Thanks again!
Glad it worked out!
this solution works for me, thanks.
