1
Change colour in animated gif
Jul 17, 2017 Jul 17, 2017
I have an animated gif and need to change the colour - I'm new to Photoshop
47.3K
Community Expert , Jul 18, 2017 Jul 18, 2017
Put a solid color fill layer at the top of the layer stack. Set the blending mode to color
Then Export - Save for web with settings as shown
Dave
Adobe
Unless you provide more information, in particular the image in question or a meaningful screenshot (including the relevant Panels), it might be difficult to provide pertinent advice.
Hi, this is the image - Thanks
Hi
This is just a gradient fill layer - set to radial and with blending mode set to color at the top of the layer stack
Dave
Hi Dave Thanks
I'm just looking to change to a single color - Red.
I tried  "Save For Web (Legacy), but double click on individual colors in the export dialog's Color Table, to change that specific color"  but the GIF is only showing grayed out Color Table.
When I get the colors working how do I get each individual circle in the GIF to change to RED
Dave
Thanks Dave - Brilliant!
May 17, 2019 May 17, 2019
Hi Dave,
I followed same process but applied color apply on complete area not on the animated text, why it is?
Is there a background?
No text images are transparent...
Yes but is there a background below those text images? There was in my example.
Dave
Hi Dave,
I have added a red color of last layer/below of all layers to show the transparency.
I have given a new file and added a red color box/object with transparency and applied a green color fill and used color blending.
But I am still getting a color remaining background.
What you see is as expected.
And again:
You could alternatively use a Gradient Overlay Layer instead of a Solid Color Layer, that should not count as pixel content.
Hi
Sorry I've just edited my answer - I should have said there is a white background below the grey layers in my example.
Dave
Thanks Dave.
Now it is working ....
Thanks all of you for your time to give me solutions!
Sorry .... but the animation won't be transparent after adding a white background.
How often do I have to repeat that a Gradient Overlay Adjustment Layer provides an alternative?
May 18, 2019 May 18, 2019
Sorry, I misspoke, I meant Gradient Map Adjustment Layer …
And there is the problem, isn’t it?
I can think of a couple of approaches, depending on what sort of change you want.
Open the GIF in Photoshop. It will come in as a bunch of layers, one for each frame. If your animation is like a video, with a wide range of colors, you could put a Hue/Saturation Adjustment Layer as the topmost layer, and you can adjust the color in the Properties panel. When you add the Adjustment Layer, it will come in with a mask, which you can paint on to restrict the effect to specific areas.When you have things the way you want, File > Export > Save For Web (Legacy).
If your animation is simple, with only a few colors, you could just open it in Photoshop, and Save For Web (Legacy), but double click on individual colors in the export dialog's Color Table, to change that specific color.
Sep 02, 2023 Sep 02, 2023
change the color
