I am calling .bat file with parameter using cep engine as follows,
cep.process.createProcess("C:/Users/CS86/Documents/CSCache/Downloaded Packages/MyBat.bat","myParameter");
it is not calling .bat file.
But if I call this .bat file without parameter it works fine.
Moving to InDesign Scripting forum
You mean in the cep context or outside of it ?
Did you try running it from another application ?
I have the same issue. Did you find a solution or workaround?
