Render Queue Output To link doesn't work
May 07, 2017 May 07, 2017
Windows 10
After Effects CC
Version 14.2.0.198
The blue "Output To" link is clickable, but nothing happens when I do click on it.  I have re-installed it, cleared my preferences, and tried the "Clear Settings" option under the Sync Settings menu in the top right.
5.8K
May 08, 2017 May 08, 2017
Do you have two monitors? Is the dialog showing up elsewhere but is behind hidden by something? What about other dialog boxes like "Open" from the File menu, does that show up?
May 09, 2017 May 09, 2017
I do have two monitors, but i still can't seem to find it with all other programs minimized.  "Open" works fine.
That's definitely odd. Can you post a screen recording of this happening?
  • Does this happen in one or every project?
  • What happens if you hit the Plus icon on the left of "Output to:" to add a second output module, is that link clickable?
  • Are you able to queue to Media Encoder and choose your desired output location there?
  • Do you have any previous versions of Ae installed? If so, does the link work there?
Jun 07, 2017 Jun 07, 2017
Hi, I´m Having this same problem on AE CC 2017. I´m able to use Media Encoder, but the "Output to": link in the render queue died after about 3 weeks of working. Its the same in all projects amd in second output modules. Did not have a previous version of AE installed.
thanks,
Daniel
Adobe Employee ,
Jul 18, 2017 Jul 18, 2017
Ever solve this issue, RyanT? Please let us know so we can assist you further.
Kevin
Sep 05, 2017 Sep 05, 2017
I suddenly had the same problem last night, with After Effects CC, output to won't be clicked. In CS6 it works.
I have uninstall and reinstall the program numeral times, reset After Effects settings. I can send renders to media encoder, but this is not ideal workflow.
Can you recommend something?
Many thanks,
Elise
Jun 28, 2018 Jun 28, 2018
hello,
having exactly the same problem in the latest CC version and cant render as is...
any suggestions?
thanks
Nov 07, 2018 Nov 07, 2018
Hi
Here's how I solve this problem. There should be a folder that you can't reach. I mean sometimes Windows doesn't alllows you to delete a folder you know. You should get rid of that folder first. To specify where the folder is, go to render queue, next to "Output to" link there is a drop down menu, just click random one, and it will allow you to render at your last render directory.
Now that you know where the problem is. There should be a "non deletable folder" in that directory. Find it, erase it. The quick way to do it is, right click the folder, add to archive, select "delete files after archiving". Then simply delete the archived one.
Now the "output to" link should back again.
Apr 30, 2019 Apr 30, 2019
I followed your directions to find the folder it was defaulting to.  The folder was messed up and wouldn't allow itself to be deleted or renamed.  I did what you suggested with 7zip.  Add to archive - delete after compression.  It deleted the folder when it was done and AE immediately allowed the file dialogue box to be opened again once it was gone.  Thanks for sharing the solution!
Aug 14, 2020 Aug 14, 2020
hi alpere92752818,
Thankyou very much, it worked for me. and it also solved another problem of deleting the folders which cannot be deleted in windows, may be there are other ways to do that but your way is easy. god bless you for your help
Sep 16, 2020 Sep 16, 2020
Thank you so much! I’m so glad something finally worked! ❤️
Nov 16, 2020 Nov 16, 2020
Your a lifesaver 🙂
May 11, 2021 May 11, 2021
I am having the same issue but can not find a "non deletable" or corrupted folder.
I'm unable to change the Output Module destination path.
When I click on the "Output To" blue hilighted text nothing happens.
I have deleted prefs, uninstalled and reinstalled After Effects (2021) with no change to the issue.
New projects and new comps just keep defaulting to the same path when I add them to the render que.
This thread is the only conversation I've found relating to this "bug".
What can I do if my folders are not corrupted?
Would appreciate anyone's help with this as I'm in the middle of a big project.
Oct 21, 2021 Oct 21, 2021
PatRIGT , did you get a final solution ?
Oct 31, 2023 Oct 31, 2023
Amazing, thank you!
