Hi all,
I posted a thread to the RoboSource Control category, and
someone suggested I post a message here as well, since VSS folks
may never go into the RSC category. If you use VSS integrated with
RoboHelp, please read on. I'd like your take on how to rename and
delete folders with minimal headaches.
We use RH6 and VSS (integrated together -- we're new to using
this system with existing help projects) and had a problem in the
last few days where someone on my team renamed a folder and the
other two of us weren't able to easily obtain the "new" folder or
delete the "old" one from our systems. We soon learned that this
happened because RH doesn't tell VSS that the folder was deleted or
renamed. With Gravenstein's advice by way of the RSC forum, we
discovered that we had to do a lot of crazy stuff like manually
fixing FPJ files, deleting CPD files, and manually deleting the old
folder from VSS. We finally figured out a process (see further
below) to get this to work next time someone renames or deletes a
folder. We tested this process this morning during another
folder-renaming event. The process worked, but this amount
hoop-jumping seems ridiculous -- maybe there's something we're
missing.
Does this process look right to you, or are we performing
extra steps that could be skipped or aren't necessary if we just
did things a different way? How do you do this in your own teams?
(What steps do you go through?) Is there some setting we're missing
somewhere that would "automate" this? After all, we don't need to
do this every time someone deletes a help topic. Why is a folder
any different? Thank you so much, in advance, for any advice or
thoughts. Our "process" is pasted below. Thanks! Lisa
After the original writer has deleted a folder (or renamed a
folder), the other writers should peform these steps on their
machines:
1. Open the out-dated help project and “get”
files from VSS. This action retrieves any new folders or topics.
2. Save and close the help project.
3. In Windows Explorer, browse to the help project folder on
the C drive (located in C:\SourceControl\).
4. In the help project folder, locate the CPD file for the
help project. This file bears the name of the help project and has
a CPD extension.
5. Delete the CPD file.
6. Open the help project.
7. If a message displays asking to make an FPJ file writable
(such as the skin FPJ), click Yes.
8. If a message displays stating that an error occurred while
saving data to the FPJ file in the previous step, click OK.
9. When the message about the CPD file being corrupted
displays, click OK.
10. Close the help project.
11. Relaunch the help project and get the newest version, as
usual.
12. If any messages display about a writable copy of a file
(like the FPJ file in steps 7 and 8), select Replace your local
file with this version from SourceSafe? and click OK.
13. After files have been retrieved, open the Project tab and
verify that the old, deleted folder is absent and the new folder
(if any) is present. Verify that all topics display in the new
folder.
14. Close the help project, checking in files if prompted.
15. In Windows Explorer, manually delete the old folder from
your C drive.
16. Once all writers have synchronized their versions of the
project, one of the writers should launch VSS and manually delete
the old folder from the help project in VSS.
