Hello there,
I got a question and i can't find the answer. My blending modes don't work. And i already reinstalled PS but nothing changed .
Here you see a picture were i used the blend mode screen
But as you can see nothing happens (Black doesn't go away)
And none of the other modes work! So does someone has the answer for me?
No-one can answer your question.
Blend modes work by blending two or more layers together. Since you have not shown the inputs - we cannot tell you whether the blended output is working correctly or not.
If the top layer is the light smoke and the layer underneath is black , then that looks correct. Screening an upper layer with black underneath leaves the upper layer color unchanged
Blending modes in Adobe Photoshop
Dave
Please post a meaningful screenshot (one that includes the pertinent Panels, in this case at least the Layers Panel).
As davescm already pointed out changing the Blend Mode of one Layer without any other visible Layers present is useless.
What Dave said - the mere name of "blending mode" implies that there's always two components involved. Your image only shows one. Attempting to blend it against PS' virtual transparency will do nothing. It doesn't count.
Mylenium
