I am running Photoshop Elements 11 on a Windows 10 machine. After the most recent Windows update all the pull-down menus have no text under them. For example: when you click on 'Edit' the window opens but there is no text underneath it. Help!
Windows Version info:
OS Name Microsoft Windows 10 Pro
Version 10.0.15063 Build 15063
Elements Version info:
Adobe Photoshop Elements Version: 11.0 (11.0 (20120830.r.32025)) x32
Operating System: Windows 8 64-bit
Version: 6.2
System architecture: Intel CPU Family:6, Model:10, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
Physical processor count: 4
Processor speed: 2893 MHz
Built-in memory: 8013 MB
Free memory: 2357 MB
Memory available to Photoshop Elements: 3255 MB
Memory used by Photoshop Elements: 70 %
Image tile size: 128K
Image cache levels: 6
Display: 1
Display Bounds:= top: 0, left: 0, bottom: 1080, right: 1920
Video Card Number: 1
Video Card: Intel(R) HD Graphics
Driver Version: 10.18.10.4358
Driver Date: 20151221000000.000000-000
Video Card Driver: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Video Mode: 1920 x 1080 x 4294967296 colors
Video Card Caption: Intel(R) HD Graphics
Video Card Memory: -1919 MB
Application folder: C:\Program Files (x86)\Adobe\Photoshop Elements 11\
Temporary file path: C:\Users\Derek\AppData\Local\Temp\
Photoshop Elements scratch has async I/O enabled
Scratch volume(s):
Startup, 451.4G, 63.8G free
Required Plug-ins folder: C:\Program Files (x86)\Adobe\Photoshop Elements 11\Required\
Primary Plug-ins folder: C:\Program Files (x86)\Adobe\Photoshop Elements 11\Plug-Ins\
Additional Plug-ins folder: not set
Similar issue being discussed in thread PS Elements 12 Stalling
Please see if this is helpful.
Anwesha
I saw this before posting and tried the "Ctrl + Alt + Shift" suggestion but it did not solve the problem.
I am using PS Elements 10 and have had this problem after the last 2 Microsoft WIN 10 x64 Updates. My fix is to reinstall PSE and reboot the computer (important).
Is this the only solution for my very expensive software that I bought from your company? That I have to uninstall it and reinstall it every time Windows decides to release an update?
Owners of old programs simply have problems with Windows 10... none of which is Adobe's fault... Adobe did not change your old program to make it stop working... Microsoft changed their operating system and THAT is why your old program won't work, not because of anything Adobe did... Also... every time Microsoft issues a Win10 update, there is the risk that an old program that HAS been working after the initial Win10 upgrade will STOP working... bottom line, old programs require a matching old operating system
Are you an Adobe employee?
Anwesha, it has been 25 days since I have received a response from you. With nothing else to go on I tried the suggestion of user: yys2bi4n. I uninstalled the program. When I tried to reinstall it from CD I got the following error as shown in the attached photo.
My user account on my PC does have administrator level access. Help, I now have useless software.
Insert the install disk. When queried about what to do with the disk select "Open folder to view files." Right click on the autoplay.exe file and choose "run as administrator."
This suggestion did not work. The exact same error happened.
