For some time now I am experiencing 3 to 4 purple lines across the top of the first images up to 12 approx) when importing images from a memory card.
Sometimes when I reinstall the same images they disappear or if I export to the desk top they disappear (as a jpg).
I have eliminated the following;
Camera, I have 2 cameras, a Nikon 750 and a Fujifilm X-T2. It happens on both cameras.
Memory cards, I have changed memory cards. Problem still exists.
Memory card reader, I have purchased a new one. Problem still exists.
I use an Apple iMac OS XE1 Capitan which has been ok up to now with Lightroom CC.
I shoot in Raw + Fine on the Nikon and Raw on the Fuji.
My belief is the problem is a Lightroom CC software problem as I have eliminated the associated hardware.
Can anyone help please?
Alan
In my opinion, it is unlikely that Lightroom would be causing this problem. If you are using Lightroom to import the images to your computer, that process simply copies the images from the card to the computer. All adjustments and changes made to the image are stored in the catalog. The image file itself remains unmodified. From your description of the problem, it would seem that there is a problem with the hard drive on your computer. The problem you describe is almost always an indication of a
...Copy link to clipboard
In my opinion, it is unlikely that Lightroom would be causing this problem. If you are using Lightroom to import the images to your computer, that process simply copies the images from the card to the computer. All adjustments and changes made to the image are stored in the catalog. The image file itself remains unmodified. From your description of the problem, it would seem that there is a problem with the hard drive on your computer. The problem you describe is almost always an indication of a hardware malfunction. You might also consider checking your graphics card. At any rate, I seriously doubt it is related to anything that Lightroom is doing.
Hi Jim, thanks for your help. Rather than take up space on my iMac I download images to my external hard drive. is this the area that could in your opinion be at fault? Alan
It could also be the computer memory going bad.
I agree with JimHess​, this is not a problem caused by Lightroom, which never changes your original images.
