Hello,
When I export my file to pdf, it comes up with this error message:
When I go to the links panel, all links are there and when I relink them it makes no difference.
The pdf file still saves but it is having a problem being uploaded to the POD amazon create space.
Any ideas how to rectify? I'm on a Mac.
You may have a corrupted document. Save as an IDML:
So I did that but it still said missing links... Any ideas?
I've tried deleting the images and re-placing them into the document too. Didn't work
Next thing I'd try is restoring your InDesign preferences:
Trash, Replace, Reset, or Restore the application Preferences
Thank you so much Steve, I'll try this tomorrow and see if it works.
So I reset the preferences and it made no difference. I have uninstalled and reinstalled indesign. I have re copied my image files to iCloud, and still it is showing as links missing to my files. I've tried setting up new files, used different images, opened old files that were fine and are now not.
Can anyone shed some light on this for me please?
What does iCloud have to do with this?
Nothing, but I wondered if there was a problem with my image files which were originally created on a different computer and then transferred using iCloud.
But it just seems to be a problem with indesign
Hi I am having the same issue and it is not working. There is no mising links stated until I get to export. I get the same message as this person when I am exporting. What is the solution??
Hi @Melissa3316583384ra ,
Sorry to hear about the trouble. Please try the suggestions shared in this discussion and let us know if this helps or if you need further assistance.
Rishabh
