I'd like to suggest that it be possible to move documents from the adobe cloud to the iPhone app. The app presently supports viewing the documents in the cloud, but it is not possible to move the documents from the cloud to the app if one desires to keep a copy of it on the device. Could someone consider this feature request? Thank you.
Hi jaalburquerque,
We appreciate your feedback.
You may also try this as a workaround.
Send the document from the Document Cloud to your own email account.
Once you receive the document in the email account, open the file.
Then use "More" option and select "Copy to Adobe Acrobat". This will save a copy to local in Adobe Acrobat application.
Check if this helps.
Let us know if you have any questions or need any help.
Meenakshi
Hi jaalburquerque,
Sorry for the delay in response.
Sorry as there is no direct option to move the PDF files from Document Cloud to iPhone app.
You may fill the feature request form for this here: Feature Request/Bug Report Form
You can try once the share PDF option in Adobe Acrobat Reader on iOS.
Open PDF and click on Share PDF icon as shown below:
Then select "Open In" from the list.
Let us know if you need any help.
Meenakshi
Hi. Thanks for replying. I tried to use "Open In..." on a document in the cloud, but it is not possible to open the document in Acrobat Reader because it does not show up on the list of apps to open with. The request that I'm making is to be able to move the document from the cloud to the Acrobat Reader app so the method described was unsuccessful.
I filed a feature request using the link that you provided. Thanks.
Hi jaalburquerque,
Meenakshi
Yes, this works. However, it still would be nice to be able to do this all at once within the app. Adobe will consider my feature request, wont they?
Hi jaalburquerque,
Glad to know it worked.
Sure, the team will look into the feedback/ feature request provided by you.
Meenakshi
Hi all
I'd like to request the same as well, i love the app and count on it for long time, but it would be really nice to be able to read the files saved in cloud offline and have the option to save them back to the local folder without having to go around the email, especially if we're talking about bunch of documents
thank you,
best regards
