The menu item under 'type' - 'Document footnote options', has vanished from the menu. It is not available when I run a 'find' either. It is as if it never was there...
That is surprising.
Have you customized your menu? (Edit->Menus...)
From there you can check if you have toggled off the visibility for Document Footnote options.
Otherwise, you can clean your cache and preferences.Troubleshooting 101: Replace, or "trash" your InDesign preferences
-Aman
Dear Aman
Thanks for your answer
I attach a screen shot of the Menu Customization to prove that there is no 'Document footnote option', to toggle off. It should be under 'Type' but is not listed.
I tried the manual clean of the cache and preferences but to no avail.
What do you suggest?
J
Did you try the other option? of cleaning cache and preferences?
-Aman
Yes I did but no difference...
I'd suggest using the CC desktop app to uninstall InDesign and reinstall. It shouldn't take long to do.
