When I zoom out of a 40pp Indesign document the view on screen is one long column. What I'd like to see is all the pages grouped (in order) horizontally and vertically in a grid pattern as oppose to one long column.
Is Indesign capable of such a view? I think this could be a real asset to have.
What I view on my monitor when zoomed out…
How I want to view my document…
Any help or a solution would be great.
Thanks in advance.
You can get quite close: Open the pages panel as wide as it will go. Set the view to '"horizontal" (View Pages > Horizontally), and the thumbnail size to "Jumbo" (Panel Options > Pages size). You don't see the pasteboard this way though, but you do see the pages.
Ariel
PS If you save this as a custom workspace, you can quickly switch to this "plan" view and back...
Hi Ariel,
Thanks for your idea, I can see what you mean…
Unfortunately it doesn't quite solve why I need the grid view. I'd need to be able to edit select/copy/cut/paste/delete throughout the document and the Pages panel is just a preview.
Cheers
Martin
Right -- the only thing you could do this way is to rearrange pages...
The only other idea I have is to open several windows (Arrange > New Window), and then choose one of the tiling options, so you can have multiple views of your document open simultaneously...
Ariel
PS Is Chuzz short for Chuzzlewit by any chance? 🙂
What Timothy said is the only closest solution to your problem, i can think of.
You can file a feature request to Adobe here Feature Request/Bug Report Form
-Aman
Thanks, years later this helped me!
Exactly what I was looking for.
Sort of like a "Slide Sorter" in a presentation application? Is that what you're going for? When I have had ID files that I need to rearrange, or duplicate plages, throughout I end up doing in Acrobat PDF after words. It's easier to look at the pages tray on the side. Drag it out, and now I see it like a Slide Sorter view which I can then rearrange, copy and paste, etc...
Hi Mark,
Thanks for your reply. Not just a page order configuration – "I'd need to be able to edit select/copy/cut/paste/delete throughout the document…" Not the pages but individual elements on the pages.
What's up?
See my screenshot:
Just do "new window":
P.S. Yes, you need to arrange "by hands" pages and do equal scaling in the windows, but this is not so big problem. IMHO
