I am unable to get the reference of the OSGI Services when ran through Mockito. Every time I run the Test Class it gives me null wherever that service is invoked.
Any help is highly appreciated.
I am following this tutorial: Apache Sling - OSGi Mocks , but no luck.
Below is the code snippet (Test Class) that i run:
HashMap<Object, Object> _configServiceEndpoint = new HashMap<Object, Object>();
HashMap<Object, Object> _configCommonConfig = new HashMap<Object, Object>();
/** Mocking required sling request params */
slingRequest = mock(SlingHttpServletRequest.class);
slingResponse = mock(SlingHttpServletResponse.class);
/** Setting Service End Point */
_configServiceEndpoint.put("sendEmailURL",
"https://MLIGATEWAY.MAXLIFEINSURANCE.COM/mli/prod/soa/MLI_E-mail_rest");
_configServiceEndpoint.put("sendSmsURL", "https://gatewayuat.maxlifeinsurance.com/apimgm/sb/soa/sms/v2/real");
_configServiceEndpoint.put("otpGenerationURL",
_configServiceEndpoint.put("otpValidationURL",
serviceEndPointConfigImpl = context.registerInjectActivateService(new ServiceEndPointImpl(),
_configServiceEndpoint);
/** Mocking up the timeout config needed for service Agent class */
_configCommonConfig.put("serviceTimeOut", "25000");
//commonConfigImpl = context.registerInjectActivateService(new CommonConfigImpl(), _configCommonConfig);
GenerateOTP generateOTP = new GenerateOTP();
SendOtpSms sendOtpSms = new SendOtpSms();
SendOtpEmail sendOtpEmail = new SendOtpEmail();
//ServiceAgent serviceAgent = new ServiceAgent();
CommonConfigImpl commonConfig = new CommonConfigImpl();
commonConfig = mock(CommonConfigImpl.class);
serviceAgent = mock(ServiceAgent.class);
BundleContext bundleContext = MockOsgi.newBundleContext();
MockOsgi.activate(commonConfig, bundleContext, _configCommonConfig);
//MockOsgi.injectServices(cmConfig, bundleContext);
MockOsgi.activate(serviceAgent, bundleContext);
MockOsgi.injectServices(commonConfig, bundleContext);
MockOsgi.activate(generateOTP, bundleContext);
MockOsgi.injectServices(serviceAgent, bundleContext);
MockOsgi.activate(sendOtpSms, bundleContext);
MockOsgi.activate(sendOtpEmail, bundleContext);
@Test
public void testMethods() throws Exception{
this.doGet(slingRequest, slingResponse);
The class where "doGet" is implemented, has two service References which internally reference another Service.
It gives me the following error:
org.apache.sling.testing.mock.osgi.ReferenceViolationException: Unable to inject mandatory reference 'commonConfig' for class com.mli.neo.global.http.ServiceAgent : no matching services were found.
at org.apache.sling.testing.mock.osgi.OsgiServiceUtil.injectServiceReference(OsgiServiceUtil.java:407)
at org.apache.sling.testing.mock.osgi.OsgiServiceUtil.injectServices(OsgiServiceUtil.java:390)
at org.apache.sling.testing.mock.osgi.MockOsgi.injectServices(MockOsgi.java:148)
at com.mli.neo.global.SendOTPTest.<init>(SendOTPTest.java:90)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.junit.runners.BlockJUnit4ClassRunner.createTest(BlockJUnit4ClassRunner.java:178)
at org.junit.runners.BlockJUnit4ClassRunner$1.runReflectiveCall(BlockJUnit4ClassRunner.java:227)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.BlockJUnit4ClassRunner.methodBlock(BlockJUnit4ClassRunner.java:224)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:69)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:48)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:292)
at org.mockito.internal.runners.JUnit45AndHigherRunnerImpl.run(JUnit45AndHigherRunnerImpl.java:37)
at org.mockito.runners.MockitoJUnitRunner.run(MockitoJUnitRunner.java:62)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
Request a concrete solution to achieve this. Any help is highly appreciated.
Regards,Deepak Kumar
Solved! Go to Solution.
Total Likes
It's been a while, but if you want to mockInject an OSGI service into your underTest object, then you must use MockitoExtension, so you can @injectMocks. And the WCM IO testing library to register the OSGI service into the calling container, https://wcm.io/testing/.
Here's some example code:
import io.wcm.testing.mock.aem.junit5.AemContext;
import org.apache.sling.api.resource.Resource;
import org.junit.jupiter.api.Test;
import org.junit.jupiter.api.extension.ExtendWith;
import org.mockito.InjectMocks;
import org.mockito.Mock;
import org.mockito.junit.jupiter.MockitoExtension;
import io.wcm.testing.mock.aem.junit5.AemContextExtension;
import static org.junit.jupiter.api.Assertions.assertEquals;
import static org.mockito.Mockito.when;
@ExtendWith({ AemContextExtension.class, MockitoExtension.class })
class MySlingModelTest {
private final AemContext aemContext = AppAemContext.newAemContext();
@Mock
Resource resource;
@Mock
MyConfigurationService myConfigurationService;
@InjectMocks
MySlingModel slingModel;
@test
void testSlingModel() {
// Register the configuration service in the AemContext
aemContext.registerService(MyConfigurationService.class, myConfigurationService);
// Mock the behavior of the resource and myConfigurationService
when(resource.getPath()).thenReturn("/content/mypage");
when(myConfigurationService.getConfiguration()).thenReturn("Test Configuration");
// Adapt the sling model using the AemContext
slingModel = aemContext.adaptTo(MySlingModel.class);
// Call a method on the sling model
String result = slingModel.getTitle();
// Assert the expected result
assertEquals("My Title", result);
@Mock
Resource resource;
@Mock
@InjectMocks
@test
