I'm using LR5 and all went well until a few weeks ago I upgraded to macOS Sierra 10.12.5
Now I cannot import any images. I have them on my hard disk and LR shows the folders, but no images.
Can anyone advise? I tried a test version LR6 but the same happened.
Arthur
Click on Copy
Make sure the Destination Panel on the right is present and expanded and has a valid destination folder selected. If it is not present, right click (Windows) or Ctrl-click (Mac) in the middle of words "File Handling", then select Destination from the drop down menu.
Click back to ADD
Explain in a lot more detail. Show us screen captures.
When I go to the import page, the following shows what I see.
I don't know if you did something wrong, or if the forum software is mis-behaving, but your screen capture does not appear. Could you please try again, or describe the problem with lots and lots of detail.
I'll try again - if the screen shot works, it's better than describing
Click on Copy
Click back to ADD
Brilliant!
Many thanks
Arthur
