Just purchased single user lightroom 6. It gave me 6.0 and my camera needs 6.7 at least. I see the update list. Do I need to update all of those updates to get to the number I need? It seems to download a big file each time.
You will already have the CC App installed. It will be like the below, except showing Lightroom (where mine shows Dreamweaver). Use this to update automatically straight to 6.12.
I've no idea why previous posts are pointing you to direct downloads.
John
Manually download and install the 6.12 update from here.
it gives me a bunch of files WinRAR and I don't know which ones to click on.
And can I update from 6.0 straight to 6.12??
Yes, you can.
In the link I provided you Expand the LR 6 link and then go to the OS you are using, Windows or Mac OS X, and download the 6.12/CC 2015.12 update. That will be either a .exe file or a .dmg file, Windows or OS X respectively. There are NO WinRAR files involved.
Once the proper file is downloaded double click on it to start the install of the update.
it is giving me a zip file...
Inside the Zip file is AdobePatchInstaller.exe and a folder.
WinRAR is probably set to be your default app for opening zip file.
Use it to unzip and see AdobePatchInstaller.exe. Double click that file.
John Waller​ I did get that file but double clicking on it did nothing.. Just Shoot Me​ I installed Winzip to see if that made a difference and I still did not get a setup.exe file. Can I uninstall and reinstall ??? I am beyond frustrated Going on over 3 hours and still can't do anything with my new camera. Hate I dropped my old one!
So it does. Never saw that before. So use WinZip or the OS as I think Win 10 has a Zip extraction, expander, utility built into it and see is you get a Setup.exe file.
No need to download 6.1, 6.2 etc to get to 6.12.
Just download the latest version. It contains all fixes and features found in the earlier versions.
John
As I read the original post, the OP has purchased Lightroom 6 standalone and was already browsing the direct download list.
"Update list" is not the same as "direct download list", and the OP gave no indication of needing non-standard methods of updating.
Fair comment, John. Just saying how I interpreted it. The mention of all those updates (which I assume means 6.1 to 6.12 inclusive) steered me. Just Shoot Me may have done the same.
I did not even think about the CC App until you mentioned it. We all see things differently. You may well be correct.
I totally understand why we expect complications with 6.0 questions. Too often people do have the CC App but it tells them they are up-to-date when they actually have 6.0. That's something Adobe has to fix.
Agreed. I've seen it myself.
john beardsworth​ so what do I do??? I had stand alone 4 and 5 and never had this issue.. and is CC app something I have to have? I don't want to pay monthly which is why I purchased the stand alone..
I did this through my photoshop program and low and behold it updated my lightroom. Thank you
Okay, This is what I have found.. I downloaded the Lightroom 6.0 onto my work computer (which does not have any other form of Lightroom on it) and it downloaded perfectly. I went into lightroom and hit update and it updated it to the 6.12 and the 9.7 camera raw files which I needed to use my Nikon D3400 with the AF-P lens. BUT, I need to figure out WHY it will not download and install properly on my home computer.. I have so many photo editing programs on there I am thinking that something is messed up . I do have lightroom 4 and 5. Has anyone else figured out how to correct this. ?? Thank you for all your help so far.
