I'm trying to make a line on Photoshop using the line tool and it's just creating a huge black and white arrow sort of shape instead of the simple line. Does anyone have any idea on how to make this stop so I can just do my line? Thank you so much!
I'd also like to make the background of the file the grey and white checkers so that it won't have a background. Thanks!
For the line :
With the line tool selected go to the options bar.
Set the fil - Stroke - Sixe and arrowheads as required
Then draw your line
For the background :
In the layers panel click on the lock symbol to convert from background layer to Layer 0
Then Ctrl+A to select all - then press the Delete key to delete the background
Dave
Adding to Dave's comment, you need to use the Weight field in the Options bar to set the line thickness
