I want to change the date on the cover of an InDesign booklet, but the Text button won't let me. I have done it before but don't remember how I did it. Can anyone help?
[The duplicate thread you created Changing text on a master page? (LOCKED — Duplicate thread) is now locked.
Please post only once.]
It sounds like the cursor is going into a second frame.
Spin open the layers panel and see how many objects are on the page. If there is a larger frame, you might lock it temporarily.
Is the text frame locked? Is the text frame on a Master page? If so, is the Master based on another Master? Is the layer locked?
You need to override the master page item that you have on your document page. You can Ctrl+shift or command+shift click on a master page item to override it. Learn how to use master pages in InDesign
-Aman
How do I know if the text frame is locked? I'm just a beginner, so I don't understand many of the symbols. I tried the command+shift, but that still didn't work. I've tried clicking on layers because I used that for another frame, but that doesn't work either. In previous years it wasn't this hard to change the date.
Joanne
Keep calm and carry on.
Go to View > Screen Mode > Normal. If the item is locked you'll see a small padlock icon on any locked objects. Simply click on the lock icon with the black arrow tool to unlock the object. Or, go to Object > Unlock all on spread.
If you are still unable to resolve the issue, posting a small screenshot of the text frame may help people suggesting you a solution.
-Aman
Try this:
-OR-
When trying to follow your directions, there is no lock on the text frame, and when I select the Type tool, it goes to the far left of the frame and won’t move.
Joanne
Keep Calm and Carry On
Spinning open the layers panel proved to be the answer, but only on a previous version. For some reason, this year's page would not pick up or show the entire larger frame.
Neither one of these suggestions provides anything that responds. I do get a text cursor, but it appears all the way to the left of the box and can't be moved. There are no lock symbols. Any other suggestion? The only thing different from the last time I did this is the upgrade to 2017 version. Do you think they changed something that prevents my unlocking the text boxes on the Master pages?
