Hi Everyone,
I am a entry level scriptor and I am currently stuck on this one specific step. I am trying to have a script loop through pathItems and select a path that matches these criterias:
I have found a script that loops through pathItems and selects paths with a specific point size, but I am having trouble add the part where it selects a path with the assign color "BLACK" on the stroke. Can anyone help me with this script?
// script.name = selectPathsThisSize.jsx;
// script.description = selects pathItems that have the same supplied stroke width; limited to 3 decimals;
// script.required = a document with at least one path item;
// script.parent = CarlosCanto // 6/5/11;
// script.elegant = false;
var idoc = app.activeDocument;
var strokewidth = 2
//prompt ("Enter Stroke Width in points of paths to be selected", 0.361, "Select Paths this size:___");
for (i=0 ; i< idoc.pathItems.length; i++) {
var ipath = idoc.pathItems;
if ((ipath.strokeWidth).toFixed(3) == Number(strokewidth).toFixed(3)) {
ipath.selected = true;
app.redraw();
The property you're looking for is strokeColor.spot.name. like this:
if(ipath.strokeColor.spot.name == "BLACK")
//do something
and to check whether there's no fill, you need to check the filled property, like so
if(!ipath.filled)
//do something
then just combine both of those in the same conditional:
if(!ipath.filled && ipath.strokeColor.spot.name === "BLACK")
//do something
here's a quick snippet that's tested and working. I'm not sure why your snippet was using the toFixed() method
...Copy link to clipboard
//do something
if(!ipath.filled)
//do something
//do something
here's a quick snippet that's tested and working. I'm not sure why your snippet was using the toFixed() method. Since you were declaring a desired stroke width of 2pt, there should be no need to convert that to 2.00. if the strokeWidth of ipath is 2.25, then it's not equal to 2 or 2.00. Save yourself some calculations and leave out those extra methods.
function test()
var docRef = app.activeDocument;
var paths = docRef.pathItems;
var len = paths.length;
var strokeWidth = 2;
for(var x=0; x < len; x++)
var iPath = paths
; if(iPath.strokeWidth == strokeWidth && iPath.strokeColor.spot.name == "BLACK" && !iPath.filled)
iPath.selected = true;
test();
Oh wow, this is definately what I needed. Your script is very easy to understand. Thank you so much for explaining how which parts I need and how to put it together into a function. This is very helpful!
Glad to help. Good luck. 😃
