I have a Basic Slideshow with only a 5 images in it. I have it set on Auto-Play and the Transition is set to Horizontal. It all appears to work fine and it scrolls right-to-left as I would like. However, I want the images to Shuffle. When I click "Shuffle", the Transition switches movements to both directions instead of keeping it a Right-to-Left direction. Any ideas on how to fix this? Seems odd that activating "Shuffle" would cause the Transition to move in both directions.
I still recommend this:
I wouldn`t use SHUFFLE, if you persist on horizontal transition.
Best Regards,
Uwe
For me that sounds quite logic for horizontal transition.
If you don`t want this back and forth movement why not use blending option (smooth transition?)?
Thanks fotoreder. The banner is like a news feed, so I wanted the scrolling to travel from right-to-left in order to read better for viewers.
Best Regards,
Uwe
I would make that in Edge as animation
