Good evening,
I've been trying to import for the last 24 hours with no success, already trying re-installing or removing spaces in the path but afaik other people managed to import the same sequence being also the latest version of After Effects as shown below.
Original footage is export at 120 fps and the sequence is not being read by the program.
Without knowing anything about the specifics of your EXR files nobody can tell you much.
Mylenium
Exported out of Unreal Engine with no compression on ACEScg.
I think I've seen a similar problem a long time ago - and I believe it turned out to be a system / OS issue - not an Ae issue. That would seem to be in-line with the fact that others can open the files.
It's a long shot - but see if they will import into Media Encoder. You could then render them out them to another file or image sequence and try that in AE.
Can't even get them on Media Encoder.
Will try to find that post you're mentioning, seems like my issue, even though I can open each frame on Photoshop and they look as supposed to.
Hi bleinkz,
Sorry for this issue. Did you ever find a solution? Please let us know if you have or if you still need help.
Kevin
No I haven't
Hi bleinkz,
I believe there may be bug in importing image sequences over 99 FPS. Can you report that here? You may be able to work around the issue. I found this thread which might assist you: CreativeCOW
Try it and let us know if it worked for you.
Kevin
