Le son fonctionne bien mais la vidéo est bloquée , il n'y a pas de fluidité. Comment résoudre ce problème ?
Which version of the program are you using on what operating system?
What model of camcorder is your video coming from?
Hello, In first, Thank's for your reply .
The version of Adobe première élément est 15.
The vidéos I usually take is coming from my Sony Nex 7 camera, AVCHD files.
May I converse them in AVI files ?
I have tried to sumit an AVI file, ant the result is also bad !
DO NOT convert your video to AVI. The program should be able to edit the AVCHD files.
When you first add your video to the beginning of a project's timeline, do you see a yellow orange "render" line above this clips? This render line indicates that the program has not set up its project settings to match your video, which can can poor performance.
There is no render line yellow orange on this PC portable. When I use Adobe 1er élément on my home PC, this render line is there.
I can read all my videos files with Windows programms, successfully.
But with VLC, it is very bad ( I have last version ).
VLC is a great media player. What is "very bad" about how your video looks? Please be specific.
When starting VLC, the first images are right, but quickly, images become unreadable, as when the TV has bad debit. All is troubled. No problem with my home PC.
May be, the graphic card is obsolete. I try to update, but there is any new version for Window 10.
Do you have problems playing other videos?
In the meantime, download the free program MediaInfo and open your video clip in it. Set the program View to Tree and copy and paste the information it reports to this forum.
This will allow us to see if the problem is with the video itself.
Yes, the same problem with all my videos, opened with adobe 1er élément and VLC.
They are fine with : movie maker, film and TV, lecteur window multimédia.
I will try to get Mediainfo and ....I write you result
Général
Nom complet : D:\Bateau Castelsarrazin\Vidéos Bateau\écluse + maison pont canal.MTS
Format : BDAV
Format/Info : Blu-ray Video
Taille du fichier : 108 Mio
Durée : 40s 503 ms
Type de débit global : Variable
Débit global moyen : 22,3 Mb/s
Débit global maximum : 24,0 Mb/s
Vidéo
ID de menu : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Profil du format : High@L4
Paramètres du format, CABAC : Oui
Paramètres du format, RefFrames : 2 images
Paramètres du format, GOP : M=2, N=13
Identifiant du codec : 27
Durée : 40s 480 ms
Type de débit : Variable
Débit : 21,2 Mb/s
Débit maximum : 22,0 Mb/s
Largeur : 1 920 pixels
Hauteur : 1 080 pixels
Format à l'écran : 16/9
Images par seconde : 25,000 Im/s
Espace de couleurs : YUV
Sous-échantillonnage de la chrominance : 4:2:0
Profondeur des couleurs : 8 bits
Type de balayage : Entrelacé
Ordre de balayage, mode d'enregistrement : Trames séparées
Ordre de balayage : Ligne du haut d'abord
Bits/(Pixel*Image) : 0.409
Taille du flux : 102 Mio (95%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Paramètres du format, Endianness : Big
Identifiant du codec : 129
Durée : 40s 576 ms
Type de débit : Constant
Débit : 256 kb/s
Canaux : 2 canaux
Position des cannaux : Front: L R
Echantillonnage : 48,0 kHz
Images par seconde : 31,250 Im/s (1536 SPF)
Profondeur des couleurs : 16 bits
Mode de compression : Avec perte
Délai par rapport Vidéo : -80 ms
Taille du flux : 1,24 Mio (1%)
ServiceKind/String : Complete Main
Texte
Format : PGS
Identifiant du codec : 144
Durée : 39s 975 ms
Bonne réception, merci
I'm sorry but I don't know what the problem is on your computer. What processor do you have and with how much RAM? I guess it is possible that your system is under-powered.
But you appear to be editing standard video. There is no reason Premiere Elements or VLC would have problems with these video files.
Do you have Quicktime for Windows installed? That may install some necessary codecs and components.
So, assuming you have an adequately powerful computer, I don't know why you are having problems.
My Ram is 4 GO . The processor is AMD E-350 Processor 1,60 GHz.
Iam' going to re-install Quick time, and I tell you result
I'm sorry, Therese, but your computer is way under-powered. Your processor rates a 782 on these benchmark tests. I usually recommend a rating of at least 5000.
PassMark CPU Benchmarks - Low End CPUs
You will find trying to edit high-def video with this computer very frustrating. This low-end processor is the reason you're having the issues you are trying to edit this video.
Ok, thank you for theses responses.
I will work later on my home PC.
