hi there, i have only just started using lr and ps and i have edited my photo perfectly for what i want, then i export and save as jpg or tiff and as soon as i put the photo on another device or flash drive the image has gone over saturated and yellowy, even when i re edit and take vibrancy and everything down the colours stay the same, i need to be able to print my images same quality as they are showing on my lap top. can some one plz help me??
On the same display?
Is the display calibrated?
Lightroom is color managed, and will display images correctly, provided that you have a sound and correct monitor profile.
If you are viewing the exported images in non-color managed applications, colors will not be correct. The combination of using a non-color managed application on a wide gamut monitor will cause images to display over saturated.
It would also be helpful if you could post screenshots that illustrate the issue, and make it clear what applications they are taken from, and also if they are from your laptop, or from a different computer.
