After exporting my PNG file a white border shows up arround my design. The transparancy of the white white fade becomes a non transparant troke/blur. Below 3 images which shows te problem:
1) Original design in Photoshop
2) Settings for exporting as PNG (PNG 24, Transparancy on, can't change Matte settings)
3) Image after exporting (png looks good after exporting but by using it for the web, for example when I want to email it, the white border shows up. http://imgur.com/91qmsiR
Does anyone know how to solve this problem? Thanks for helping.
I tried opening your PNG in Photoshop above a black layer and it looks correct - I also did the same placing it in illustrator . Both treated the A channel correctly as transparency.
When placed over a black background layer both looked as below:
Dave
Can you link to the actual PNG file ?
Dave
Yes ofcourse, here is the link: Imgur: The most awesome images on the Internet
Hi
There does not appear to be anything wrong with the PNG file that you posted.
It looks like whatever you are using to combine the file with the background later is not correctly treating the transparency channel in the PNG (a PNG has RGB and a transparency channel)
Dave
Dave
Hi, but in Photoshop file is the background Transparent?
the black in the background is on a separate layer?
or are you tring to replace black background with transparency?
If so Maybe you can optimize the result using selective color selection on the black background and erasing it, leaving transparent background. Then export the file to transparent png format.
