My camera chose the wrong year for quite a number of photos (Okay, I know who really made the mistake).
In correcting this I select a few photos, go to Metadata, Edit capture time. In the dialog I select the third choice (change the file creation date for each image). But then LR won't allow either the "original time" or the "corrected time" to change. The other two options will allow changes, and do work.
Any suggestions. I'm on a Mac with the latest MacOS installed. I've just updated to the latest LR with 15.12 installed.
Thanks... Doug
You need to be using option ONE.
This is for Lr 4 but I think it applies to the latest versions.
Thanks. I found the instructions ambiguous, but option 1 did the job.
I agree. Both the instructions and Capture Time dialog could use a little clarification. Especially the dialog. When you change options in the dialog the explanation should change too
