After Effects CC 2017 Render different from preview?
Jul 23, 2017 Jul 23, 2017
Hi, I seem to be getting a repeating glitch when it comes to rendering after effects files in media encoder.
My computer has a: NVIDIA GeForce GTX 960 graphics card with 24 Gigs of RAM
16 of which are allocated for adobe software while running.
The issue occurs when I render in adobe media encoder as rendering in AE still causes the problem but it is less dramatic. In both the final render comes out with masks not being fully aligned the way they are in the AE preview. Things are slightly off and turning off OpenGl and multicore processing as stated in other forums helped, but didn't fix the issue.
I've tried many different things including clearing the cache, and changing the frame rate to no avail. And have determined they are not the cause.
The mask is on the drop above the E in michael.
AE preview below
AE Final Render below
Media Encoder Final Render below
8.6K
LEGEND , Jul 23, 2017 Jul 23, 2017
Yes, 24.042 is the set composition frame rate. I've rendered in both regular 24 fps and 24.042
this is probably the reason for inconsistencies. you are working in a non standard frame rate and rendering a standard codec. the first thing you should do is set your frame rate to a standard frame rate in all your compositions. once you do that, you should carefully at frame by frame precision look at your keyframes and layers trimming and align them back to be on frame. they have probably been offset
Advisor ,
Are you sure you are rendering to the same frame rate as the frame rate of your comp?
Are you using 3D layers?
Are you using interlaced or non-square pixel footage?
1. The rendering is set to the proper frame rate of 24 fps which is the frame rate of the actual original video file. No other video files are used or have their speed altered. All other footage is duplicate layers used for masking or replacement.
2. I am using a 3D layer which is the michael logo, but its inside a precomp file and the masked layers apply to a completely different composition.
Regular Comp
The red circle indicates the two layers which are masked, and the "Michael Overlay" is the precomp pictured below.
PreComp
In this precomp Ray-Traced 3D is enabled.
3. The footage is in pixels.
Advisor ,
Your comps(s) and footage appear to be running at 24.042 fps.
Yes, 24.042 is the set composition frame rate. I've rendered in both regular 24 fps and 24.042, along with other assorted frame rates, and it did not have any effect on the particular masking glitch. Changing said frame rate was also one of the first things I tried.
this is probably the reason for inconsistencies. you are working in a non standard frame rate and rendering a standard codec. the first thing you should do is set your frame rate to a standard frame rate in all your compositions. once you do that, you should carefully at frame by frame precision look at your keyframes and layers trimming and align them back to be on frame. they have probably been offset on sub-frames due to the shifting back to 24 fps.
once you do that, export again and make sure you match the frame rate in AME.
Advisor ,
Yes - I agree with Roei. I highly suspect this is a frame rate related issue.
Jul 25, 2017 Jul 25, 2017
Sorry for the delay in getting back to you. I changed the frame rate in all comps to 24 frames, and readjusted all the layers appropriately. This corrected issue I was having. Thanks for the help,
Nov 16, 2019 Nov 16, 2019
Hello Roei
i tgried to change all composition to 24 fps and still rendering some thing different from the preview
i put many images and its rendered just first image and duplicated it
how can i set the keyframe !!
best regards
Jul 18, 2018 Jul 18, 2018
This happens when you select preview resolution other than Full. change it to Full and you will see the same frames in preview as in final rendering video.
Oct 08, 2019 Oct 08, 2019
I'll just point out that I have a similar issue and for me the problem was that I was previewing in quarter resolution. I was working with Vegas effect and using different segments and I didn't realise this would make a difference. Just to let you know because some might have similar issues. Thanks.
