My document has a page with a 4 x 4 text table, into which I have successfully placed images sized as I want them. Now, suddenly there has been a change in the behavior, whereby the image expands to fill the available space in the table cell, and I have no success manually resizing the image by dragging its boundary edges.
If one of you can show me how to restore the earlier behavior, I would be grateful. Is that, perhaps, a property setting somewhere within the table?
jwc
We would need to know exactly what version of InDesign you're using.
The ability to create a real graphic cell was introduced in InDesign CC 2015. With earlier versions, you were anchoring a graphic into a table cell which was usually intended for text.
I'm wondering if it's been converted to a graphic cell and you have frame fitting options set to fill the frame.
Well, Steve, that is also very interesting (see my reply just posted). Would you please point me to the procedure for creating a graphic cell. Oh, and it is not not a graphic cell around text. My layout in this case calls for a 4 x 4 array of graphics within a 10 x 7.5" area in an 11 x 8.5" page.
I can also envision (since I have the copy-paste in hand) perhaps doing this without the text table altogether, which I now almost see as an hinderance.
Here's an Adobe Help tutorial on how to insert graphics into a table cell:
Thanks, but for me, a simple copy/paste sequence from source image into the text-based table cell seems to be complex.
Best,
jwc
Solved, by copying image from source and pasting it into my doc. Had never tried that before.
