SOLVED
[AEM 6.3] AEM form components with data-sly-resource result javascript errors
Avatar
Level 2
I'm trying to build a component that consists of multiple other components without duplication of code.
So I tried to build an empty component that contains a data-sly-resource to include another component
<div data-sly-resource="${'path/to/resource' @ resourceType='my/resource/type'}"></div>
This resulted in a component that can be dragged from the sidekick and is rendered correctly.
But when I try to click the component to configure the the component, instead of showing the black edit bar it throws the javascript error below.
Uncaught TypeError: Cannot read property ‘hideTitle’ of undefined
   at hideTitleExists (form.js:2430)
   at guidetouchlib.editToolbar.appendButton (form.js:2461)
   at core.js:23633
   at Array.forEach (<anonymous>)
   at guidetouchlib.editToolbar.render (core.js:23632)
   at guidetouchlib.editToolbar.render (form.js:2538)
   at guidetouchlib.editToolbar.open (core.js:9645)
   at HTMLDocument.<anonymous> (core.js:9385)
   at HTMLDocument.dispatch (jquery.js:5226)
   at HTMLDocument.elemData.handle (jquery.js:4878)
The included component is working perfectly on its own.
I have tried to add a data-sly-unwrap, without any succes
Steps to replicate this issue:
- Install AEM 6.3
- Install Adobe Forms packages ( adobe-aemfd-osx-pkg-4.0.74.zip )
- Restart AEM to complete Adobe Forms installation
- Install custom content package containing 2 components and a test form ( demo-form-sly-resource.zip - Google Drive )
- Go to test form containing the 2 components http://localhost:4502/editor.html/content/forms/af/blank-test-form.html
- Open javascript console in developer tools
- Click on child component to validate the edit bar appears
- Click on the parent component to trigger the javascript error that prevents the edit bar from appearing
Kind Regards,
Ben
Het bericht is bewerkt door: Ben Oeyen
Added steps to replicate this issue.
1 Accepted Solution
Avatar
Correct answer by
Level 7
For parent component, the editable DOM points one level down(guideNode) than what it should point to(guide), causing this JS error.
Can be fixed by changing line 100 in /etc/clientlibs/fd/af/guideTouchAuthoringEditLayer/javascript/GuideTouchAuthoringCustomToolbar.js..
Currently it is:
        if (authoringConfigJson.hideTitle) {
Change it to:
        if (authoringConfigJson && authoringConfigJson.hideTitle) {
Avatar
Level 10
Can you drag your component from the side rail?
Avatar
Level 2
Yes, it's still possible to drag the components to the page.
Only clicking on the component in the page to configure it, will result in the error and no edit bar showing.
Avatar
Correct answer by
Level 7
Currently it is:
Change it to:
Avatar
Level 2
This indeed worked but now I receive this error
guideTouchAuthoringDialog.js:1344 Uncaught TypeError: Cannot read property ‘hasOwnProperty’ of undefined
    at Object.guidetouchlib.editLayer.dialogUtils.enableVisibleOnLoad (guideTouchAuthoringDialog.js:1344)
    at eval (eval at <anonymous> (eval at guidetouchlib.editLayer.dialogUtils.getExpression (guideTouchAuthoringDialog.js:149)), <anonymous>:1:41)
    at eval (eval at guidetouchlib.editLayer.dialogUtils.getExpression (guideTouchAuthoringDialog.js:149), <anonymous>:3:24)
    at guideTouchAuthoringDialog.js:186
    at coralui2.js:35240
And adding two child components with data-sly-resource doesn't seems to work. You can only get the properties of the last child component. Getting the properties of the first child component is impossible. It is not clear is has something to do with the mentioned error.
Avatar
Level 2
when open the properties of the child component.
Avatar
Level 2
I was able to call the properties of the child component by adding a div-tag around dala-sly-resource. The div-tag contains the guideConstants.GUIDE_FIELD_WIDGET constant.
Now we receive a 404 error from the child.component.af.somprovider when we call the som expression via the toolbar.
Do we need add or change something so that we can receive the som expression?
Avatar
Level 7
Strange enough I dont see an error when clicking on Edit... I can edit but while saving it throws some error in the backend, which seems unrelated to this.
Avatar
Level 2
This is the error that I receive when selecting the properties of the child component.
The reason why I don't receive any SOM expression is because the child components don't exist beneath the parent component in CRX.
Is there a way to add the child component beneath the parent component? So we can call the SOM expression?
