I have my AE interface as dark as possible and that creates a problem.
When I import something from my creative cloud Library to the AE timeline it will be gray by default. This color is barely visible in my timeline and I have to change it over and over.
Is the anyway to change this by default? I can not seem to find an option for it in the preferences.
Regards
Niel
The Labels section in the preferences is your friend and you can manually hack the prefs file in an text editor, too.
Mylenium
Hi Mylenium
The Option to change the color of the import from Creative Cloud Library is the only one that is not available in the preferences.
Hi Niel,
Sorry for this issue. Did you ever find a solution? Please let us know if you have or if you still need help.
Kevin
Hi Kevin
No I did not find a solution because as Mylenium pointed out, that Option is not available in the Preferences.
Regards
Niel
Hi:
If you close After Effects with the color changed, it will remain changed the next time you open After Effects on that machine.
