1
Find and place images from subfolders
Jul 24, 2017 Jul 24, 2017
Hello,
I have an Indesign file with the name of the images I want to place:
Each images has it's folder and they're in a top folder named "fotos".
The structure:
fotos / 10 - description / image1
fotos / 20 - description / image2
fotos / 30 - description / image2
fotos / etc………
Here is the code I'm using:
It finds the subfolders and the images files, but don't place them into Indesign.
if(app.documents.length != 0)
var subf = Folder ("/Users/iMac/Desktop/fotos/");
var sf = subf.getFiles(onlyFolders);
var s = "";
for (var n = 0; n < sf.length; n++) {
  s += sf.name + "\r";
alert(s);
function onlyFolders(subf) {
  if (subf.name == "File") {
    return false;
  } else {
    return true;
    if(subf != null){
        // reset the Find/Change dialog
        app.findGrepPreferences = app.changeGrepPreferences = null;
        // formulate a grep search string
        app.findGrepPreferences.findWhat = '@.+?@';
        // find all occurrence, last one first
        f = app.activeDocument.findGrep (true);
        for (i = 0; i < f.length; i++){
            // construct file name
            name = f.contents.replace (/@/g, '');
            // place the image
            var placedObjects = f.insertionPoints[0].place (File (sf +  '/'+ name+'/'));
    // delete all @??@ codes
    app.activeDocument.changeGrep();
else{
   alert('Please open a document and try again.');
Here is the error from ExtendScript Toolkit:
Can I get help from you guys?!
Thank you.
Scripting
1.0K
People's Champ , Jul 25, 2017 Jul 25, 2017
The problem is that getFiles won't look at subfolders (unless I am wrong). You need a recursive function.
A possible approach:
var lib = {
getFiles : function ( fo, aExtensions, bRecursive, aFiles, includeFolder )
var exts = aExtensions? aExtensions.join("|") : ".+" ;
var pattern = new RegExp ( "\\."+exts+"$", "g" );
var files = aFiles? aFiles : [];
var filterFunction = function(file)
return pattern.test ( file.name );
if ( bRecursive )
var foFiles = fo.getFiles();
while (  f = foFiles.shift() )
if ( f
People's Champ ,
Your biggest mistake is that you are using your reference to the array of files your retrieve from the folder user selection instead of the folder itself.
//This is an array of files objects
//sf isn't the folder object !
//subf is
Hello,
Thank you for your reply.
I changed the code to:
var s = "";
alert(s);
    return false;
  } else {
    return true;
    if(subf != null){
            // place the image
            var placedObjects = f.insertionPoints[0].place (File (subf +  '/'+ name+'/'));
else{
But it returns to the top folder and don't search in the subfolders.
Do you know how can fix the code?
Thank you.
People's Champ ,
var lib = {
if ( bRecursive )
if ( f instanceof Folder )
if (includeFolder===true) files[ files.length ] = f;
this.getFiles ( f, aExtensions, true, files );
if ( f  instanceof File && pattern.test ( f.name ) && f.name!=".DS_Store" )
return files;
else
return fo.getFiles ( filterFunction );
getFilesDB:function(arrFiles){
var db = {}, n = arrFiles.length, aFile;
while ( n-- ) {
aFile = arrFiles;
db[decodeURI(aFile.name)] = aFile;
return db;
replaceFiles:function ( doc, db ){
var fgp = app.findGrepPreferences.properties,
found = [],
text,
n = 0,
fileName = "",
file;
app.findGrepPreferences.properties = {
findWhat:"@.+@",
found = doc.findGrep();
n = found.length;
while ( n-- ) {
text = found;
tf = text.parentTextFrames.length ? text.parentTextFrames[0] : text.parentStory.textContainers[0];
fileName = text.contents.replace(/@/g, "" );
file = db[fileName];
if ( file ) {
tf .contents = "";
tf.contentType = ContentType.GRAPHIC_TYPE;
tf.place ( file );
tf.fit ( FitOptions.FILL_PROPORTIONALLY );
tf.fit ( FitOptions.CENTER_CONTENT );
var main = function(paragraph) {
var doc = app.properties.activeDocument,
fo, files, db;
if ( !doc ) return;
fo = Folder.selectDialog("Please choose the parent folder" );
if ( !fo ) return;
files = lib.getFiles ( fo, ["jpe?g"], true);
if  (!files.length) {
alert("no files returned!");
return;
db = lib.getFilesDB ( files );
lib.replaceFiles ( doc, db );
var u;
app.doScript ( "main(app.activeDocument.stories[0].paragraphs[-1])",u,u,UndoModes.ENTIRE_SCRIPT, "The Script" );
Man,
you made my day!!!!
Thank you so much!!
Cheers!
People's Champ ,
Jul 26, 2017 Jul 26, 2017
Be aware it might not be bulletproof. What if several images are equally named ? Actually script "overrides" file references so the latest found file will prior when placed (I only one "1.jpg" file will be placed even if several found).
I will keep that in mind.
It works perfectly for what I need.
Thank you again!
