I followed this guide Adobe InDesign Tips: Japanese/CJK Functionality + English UI to install inDesign in English with some added features only available in the Japanese version. This was done for the purpose of using ruby on top of the Japanese Kanji.
I am new to inDesign. I am trying to create a document that has two columns. The left column will contain English text only, and the right column will contain Japanese text only (horizontal text, not vertical). I want the English text to flow to the next page and stay on the left column only. I want the same for the Japanese text, but have it stay on the right column. I already have the English text in a .txt document, and the Japanese text in a word document.
Next, I want to add the ruby (furigana) over the Kanji for the Japanese text. This should be possible after following the guide from the link above.
Next, I want to align each paragraph with it's respective translation. I will also need to do the proper typesetting for both texts.
This is intended to be eventually printed. I thought a 6in x 9in (215.9 mm x 279.4 mm), 2 column, 13 mm margin document would be a good size to work with.
This image gives a general idea of what I am shooting for.
source of text: Nippon Talk – Japanese Daycares – 日本の保育園
How do I do what I want? I appreciate any help I can get.
Thanks for the responses. I am going to try a bit more now.
Edit: Well, this task is too much of an undertaking for me. I still can't get the columns to work, and after playing with the ruby setting, it looks like I have to manually enter the kana for each kanji, and there are thousands of them. It's just not possible. I think I just have to give up. Thanks to everyone that took the time to answer my questions.
Since you already have installed the English UI InDesign with Japanese features, rest of the part only involves figuring out what Ruby and kanji settings are and where these options are....
I suggest you create two separate text frames (not one frame with two columns) and use them for English and Japanese text. You also have the text available with you in two word files.
So all you need to do is,
1. Create two frames, one on the left and one on the right
2. Place the word and txt files in those frames separately (File-> place)
3. Use the Japanese features to style your text as needed.
-Aman
When I try, the text flows from the left column to the right. How do I keep left to left, and right to right?
That looks great and could be very helpful, but it doesn't explain how.
Are you creating a single frame with two columns?
What i was suggesting was to create 2 separate frame (one for English, one for Japanese).
Some thing like...
I have created 2 frames on the page (one for English, one for Japanese). The same is for all the pages of the document. Since the frames are different, my English text would remain on the left forever and wont mix with the Japanese text. Moreover, i can apply individual styles and properties to the text. I hope the idea is conveyed now. The only extra thing, i have done is to thread the English frames together and Japanese frames together, so that the text text flows from one English frame to another English frame.
-Aman
As Aman said, 2 frames flows!
If you have the same paras settings, you could align the paras with "manual" hard-returns!
My script is more powerful and plays the game in all cases!
It simply extracts the vertical position of each para, compares them and makes calculations to align the corresponding paras!
if the layout moves, just 1 click to play the game again! …
Hi
I don't know anything about Japanese and how you generate "rubys"
Let's assume you have a unique English paragraph and a unique Japanese paragraph each time.
Here's an alternative workaround you might find helpful (or not ^^)
First, you must have your text set as follows:
I understand this would require extra work since you have separate text files, but if this is acceptable to you, you can keep reading...
The idea is to :
See example:
Hi Vinny,
What about paras between 2 pages?!
Of course, if you consider this case never happens, … !
Hi Obi,
Good point!
it sure would prevent paragraphs to run across 2 pages
Now, it might not be that bad, depending on how OP wants to set up his document. It might give better readability.
But it's a limitation (maybe not the only one) that is worth being raised.
Hmmm... I see what you meant...
Japanese para may start in next page, left column if much larger than the English one.
Not so good!
I'd probably use a 2 column table with a new row starting anywhere you need maintain the alignment between the left and right columns.
Same issue about paras between 2 pages!
