Hi
Could You helm me?
In my project the line is green but dotted. However, while watching, the picture is jammed while the sound is smooth. what am I doing wrong?
I have got:
Adobe Premiere Elements 15
Computer: 2 GHz, RAM 4 GB, 64 bit, Windows home 10
Recordings: 1280x720, 30 fps (using the gimbal Smooth q application)
Presets AVCHD 1080p60
Can anyone guess what I'm doing wrong and could help me?
thanks
Tom
What processor do you have?
Based on your monitor resolution, I'd expect that this is a lower-powered laptop. But it's hard to say without knowing which processor you have.
Intel Core i3 5005U 2 GHz
is that not compatible with Adobe Premiere Elements system requirements ?
On this chart, your processor rates a 2900. I usually recommend at least a 5000 benchmark for editing with Premiere Elements. Still, even with your processor you should be able to do some basic editing.
Maybe the performance issues are being compounded by the fact that you're trying to edit 60p video. Can you try shooting in 30 fps and see if that video edits more easily?
Also, can you confirm that, when you add your video to the beginning of the timeline, you do NOT see a yellow orange "render" line above the clips? This yellow orange line indicates that the program has not matched its project settings to your video specs, which can result in poor performance.
yes, the line is orange:( What can I do to resolve it?
Does that all mean that to use 60fps it need a better processor?
Thank You for your help
Please download the free program MediaInfo and open one of your video clips in it. Set MediaInfo's View to Tree, then copy the data it reports and paste it to this forum.
You're dealing with video that has some unusual specs, so we'll need to find out what those specs are before we can recommend a solution.
I think, I am doing something wrong way...
Pełna ścieżka : C:\Users\Tomek\Documents\Adobe\Premiere Elements\15.0\Bulwary_200717.prel
Format : GZip
Profil formatu : deflate
Rozmiar pliku : 87,8 KiB
You are not seeing the complete MediaInfo report. As I said, you need to set MediaInfo's View menu to Tree.
I am sorry, but i don't know how can I do it? Could you send me any instructions?
I'm not sure how to say it more simply. Open your video file in MediaInfo. On the MediaInfo program, select View and, from that menu, select Tree.
I am doing it that way (?)
I understand that's not about it?
When View is set to Tree, it should look more like this:
Such a view, I'm just picking. Then I choose the wrong file. Where and in what format should the file upload?
during editing "while watching, the picture is jammed while the sound is smooth"
I also had this problem and discovered my laptop has two graphics cards, one for power saving (general use) and one high performance for gaming. along with the above symptom was a very large ram demand that worsened to about 40 clips when premier crashed with a low memory alert(34Gb required). after trying may things...... i finally found the that by disabling the gaming video card (nvidia) and using the general video card (intel), all my troubles went away. i am so happy it's all working smoothly now and only using 4Gb for the same 40 clips.
