RH 5, HTML.
I am using a numbered list (based on default css) and it
appears to be perfectly aligned from WYSIWYG, but when I view the
topic by clicking View Select Item (eyeglass icon) the list is not
aligned appropriately - some numbers are indented more than others.
Usually when things like this happen, which I cannot explain,
I right click on the line where the text is and usually there are
"span attributes" that I can remove to correct the issue, but there
are no attributes for the list.
This particular list is embedded within a chart (all
step-by-step instructions are in a single column, but listed in
multiple rows/cells), but I've also encountered the same issue when
working with a number list outside of a chart.
Does anyone know why this is happening & what I can do to
correct it?
Eva
