White Lines Showing Up on Print
Jul 28, 2017 Jul 28, 2017
I have an InDesign Document that I have exported to a .pdf and am trying to print.  Whenever I print it, these thin white lines are showing up above and below some of my text.  They are not visible on my screen when I vies the .pdf or the .indd file, it is only when I print it out.  I have also tried printing it on a higher resolution color printer, and they are still there.  Any idea what I can do to make them go away?
3.6K
Community Expert , Jul 28, 2017 Jul 28, 2017
Then it looks like stitching artifacts. Again, try the PDF/X-4 format with exporting.
Does this happen when you print directly from InDesign? Or just from the exported PDF?
Unfortunately I have to send a .pdf version of the file to the publication that will be printing this.
Have you tried printing it out directly from th InDesign file? Also try printing a page of the pdf from Photoshop to help narrow down the problem.
Were we typing at the same time again?
That was just too weird!
I will try the Photoshop suggestion. Thanks!
How are you exporting the PDF? What are your export settings?
I packaged the file and printed the pdf from there.  I haven't changed any settings so they are whatever the default settings are.  I have printed many other pdfs this way and haven't encountered this problem before so I'm not sure why it is happening with this particular file.
Try to export using PDF/X-4.
Is there any transparency involved here?
Yes, the picture I'm using as the background is at 50% opacity.
Okay, thank you very much!
Jan 28, 2018 Jan 28, 2018
Thank you BobLevine for the PDF/X-4 tip. Worked a treat as I was having the same issues.
Apr 01, 2019 Apr 01, 2019
Thank you, Bob Levine. I had this issue today. This tip worked well.
