Creating Multi-page pdfs in Photoshop CC
Jul 28, 2017 Jul 28, 2017
I'm a very novice, former Photoshop Elements user, with a trial version of Photography Creative Cloud.
I'm trying to figure out if there is a way to create a TWO-PAGE photoshop pdf, using one image for the 1st page and a different image for the 2nd page.
I'm trying to create a single, two-page, printable pdf with high resolution so it can print with high quality.  I can't find a way to do this in Photoshop Elements or in Photoshop CC / Lightroom CC.   What I'm trying to do, in this instance, is create baseball cards on card stock (9 cards per 8.5x11 sheet).  So I need a single file I can bring to a print shop that has the front of the cards on page 1 and the back of the cards on page 2.  I have the images for the front of the sheet, and the image for the back of the sheet...I just don't know how to get them into a single-document format that will print with high quality. I know there is a way to combine pdfs in "Preview" on a Mac, but that appears to result in lost quality of the images.  And I've read the same is true if you create a "pdf slide show" (as opposed to a photoshop pdf that isn't a slide show).   Again..I'm new/novice...so I appreciate guidance from the very experienced community here.
Thanks.
47.4K
Adobe
In photoshop cc try File>Automate>PDF Presentation
Create a PDF Presentation in Photoshop CC - YouTube
What version of photoshop elements do you have?
In some older versions there is a workaround way to save multi-page pdfs.
Thanks.  Does creating a "Pdf Presentation" reduce the resolution/quality of the images?  In other words if I create this 2-page PDF Presentation file as you described and have it printed, would it the the same quality as if I took the same two "Photoshop PDF" files I created in Photoshop Elements 12 (that's the version I have) and had them print "file 1" on the front and "file 2" on the back (separately...would have to run through printer twice)?   I ask because when I used Preview to combine 2 pdfs into 1, the one resulting file was something like 5x smaller than either of the individual files was by itself...so I know something was lost in that process.  Thanks again for your response.
That depends on how you set it up. When you choose Multi-Page Document and click Save on the initial PDF Presentation dialog box, another dialog box pops up called Save Adobe PDF. These are all of the options that determine the color, resolution, etc. of the PDF presentation. It looks complicated, but usually you only have to choose a preset that fits the kind of output you need and then you're done. There are low resolution presets for screen viewing, high resolution presets for printing on desktop printers, printing presses, etc.
You need to ask the print shop if there is a PDF preset they would recommend that you choose. Because PDF is a widely used format in print shops, many of them can either tell you which PDF preset to choose to preserve the most quality on their equipment, or they will send you a preset they created for their shop and ask you to install it and then choose that from the Adobe PDF Preset menu at the top. You'll see that Photoshop already has a number of built-in presets for the PDF/X commercial printing standard, but you won't know which version to choose (PDF/X-1a? PDF/X-4?) until you ask the print shop which one they use.
Apple Preview also has a way to generate PDF-X files, but it isn't as straightforward. A print shop will typically prefer a PDF generated directly from Adobe software.
Mentor ,
You should talk to the print vendor and get their file preparation requirements.  They may want to use a special paper and document size to get the 9-up to print to include bleed and the ability to trim out the 9 cards without misalignments.  Technically, you would send them 2 CMYK Photoshop PDF files @ whatever resolution they require.  So, consult with them, then you will have more information to help you move forward.
Mentor ,
Also, keep in mind most offset print machines require an area known as "gripper" that has to be included in the document size.
Oct 22, 2019 Oct 22, 2019
Yes or otherwise with Adobe Acrobat Pro it's very simple:
We open its PDF then
Tools / Pages / Insert from a file.
And we add already Dear Loving Morning PDF pages to his document.
My version is not very recent but it must be similar on the news. Creating a Multi Page in Photoshop . Step 1: Save each .PSD file in the same folder. Step 2: For easy management, save each page as Page_1, Page_2, etc. Step 3: Next, go to File, then Automate, then PDF Presentation. Step 4: Click on the new pop-up. Step 5: Hold Ctrl and click on each
