How do you place a square-format grid placed exactly in the middle of the document? Now it's going out of the document to 900 mm. I tried different values, but they all give me wrong result, sometimes it' goes far out of the document. I want it palced so that there is equal boxed all over the document. I want it stop 857 mm exactly.
Would be glad if anyone could specify the exact values I need to put in, or any other way to solve this problem.
Kind, Modassir
What page size are you using?
To make the grid of squares end with full squares at your page edges, you need to know what dimension as a square will fit.
For example, if you have an 8.5" x 11" sheet, then your squares cannot be 1" square, because that doesn't divide evenly into the 8.5" side.
You'd have to use .5" squares to make that work.
as in using grid lines? like attached?
not create guides, but grid, option is under preference then grid, that one
You can split a frame into a grid as your are creating it.,
For no gutter, go to Margins and Columns, and set gutter to Zero for the page
Draw a frame exactly the size of the page, and without letting go of the mouse button, use the up and right arrow buttons. Your frame will divide itself as much as you want into equal portions.
I agree with SJRiegel. You can make any text or graphic frame split into a grid by using your arrows while you are still holding the mouse down when you draw the shape.
i use the guides on a separate layer and lock it and use it as my grid to layout. do it for web mockups of magazine layout. i find that works. sorry. i don't use that option you speak of.
Yeah! It worked! Thanks!
