I have a paragraph split into 2 columns, divided by the gutter. Everything looks correct however I want the text to read continuously left to right, not divided into columns. Is there a setting to change text flow, or another method to achieve this?
Attached is a screenshot for reference. The goal is to make it read "This is a test" continuously left to right.
Thank you!
Simply draw a no stroke / no fill rectangle in the center gutter and apply Text Wrap to it.
With the text box selected open the Text Frame Options dialog box (Command/Control-B) and make sure that the frame is set to one column. See screenshot:
Thank you for the reply. However, I want to maintain the gap between the gutter. Is there another way to achieve this besides 2 columns?
I'm not sure why you would want to do this since a gap in the middle of a sentence seems kind of disconcerting. I don't know if there if there is a way. Even inserting tabs or using a flush space would be imprecise since the text would vary from line to line and be very difficult to line up in the manner you're requesting.
The gutter will ultimately be a fold and I don't want the text to be illegible due to the crease the fold will make, so want to space the text around the crease. I would break the text into columned rows but there simply isn't enough real estate. If this isn't easily possible then I'll experiment with out layouts.
If the gutter is to be a fold then why would you want the text to go across that fold? I did look at InDesign's Split column feature but even that does not provide an option to make the text read the way you're looking for.
That one was staring me right in the face it was so obvious! Bravo, Michael!
