Picture was rejected because of technical error. But what one? White balance?
It is a striking photo, but perhaps it reads too dark? I would try adjusting levels, then maybe play with contrast and brightness to make the clouds more dramatic.
You mean something like this? Darkness is an important part of atmosphere. I don't sure, if the more brighter image would fit.
That is a good start, the clouds are more dramatic without becoming bright. Not sure what else they are looking for. I am new here, and a novice at stock photography. I understand not wanting to go too light, and agree with you on that. Can you bring out a little detail in the cross without creating too much 'noise' ?
Next try The problem is, I do not know, what was the issue with the first image 😕
I like that much better! Not sure if it's what they were looking for, maybe someone with more experience here can chime in . I like the original too, but from what I have been reading here, images have to meet certain standards in order to be of interest to customers. I have so much to learn!
Maybe try uploading it again? See what happens? Good luck!
Thank you very much. I'm also new to stock photography and photography in general. So, I'll follow your advice and try to upload the last edit again
