How to alter a web slide show in PhotoShop CS5
Jul 31, 2017 Jul 31, 2017
I have created a slide show using the bridge (or mini bridge- I forget which right now) but there is a an obnoxious range of transitions between the images.  How do I change this?  All that I want is either a simple replacement or fade between images.
829
Community Expert , Jul 31, 2017 Jul 31, 2017
I grabbed my old CS5 workbook to refresh my memory. There were two output options—PDF and Web Gallery. I don't remember that there were transitions for the Web Gallery, but I can see from the book that it created an index.html file that managed the display of multiple images.
Adobe
If you do not remember what you did or what you created how could we know?  My car I forgot where I parked it how can I make it run the way I want it to. Where is my car? May be still where I parked it last.
JJMack
Thank you so much for your snarky answer.  Your in-depth observation has added so much to the discussion.  By the way, it was the mini bridge.
Guru ,
I have never made these kind of slide shows, however, from bridge you exported a .pdf or web gallery, your post doest not say which one, for either option  I would remake it and change your settings in the playback options:
Here is a video that might help:
create a slideshow with adobe bridge cs6 - YouTube
Thank you very much for your help.  I will check it out later today.
Photoshop CS5 also has and optional Web  Photoshop Gallery plug-in that could generate Web sideshow there were no transitions possible.  CS5 Bridges output module could also generate Web Photo Galleries and slideshows.   If you still have the source image files you used to generate the slideshow you can redo the slideshow you generated and chang the setting used to generated the slideshow. It would most likely be easier to re-generate the Slideshow than modifying the current slideshow you have.
JJMack
thank you for your answer, but I prefer to get help from someone who does not need to boost his own ego at my expense.
Your logic elude me. Did I some how extract money from you or just point out  you provide little to go on.
JJMack
It's a PDF slideshow, right? You can disable the transitions in Acrobat. Which version of Acrobat do you have—I'm happy to give instructions.
Or, if you don't have Acrobat (just Reader) you can download a free Adobe Acrobat DC trial:
Thanks, but I want to keep the images in .png- or at least .jpg.  They are of artwork and I want to keep as much detail as possible.
I remember the old Output module in Bridge allow you to create a PDF slideshow with transitions. Your slideshow isn't a PDF? What format is the slideshow in now?
It is in .png.  Thanks for your help.
Ha. I'm almost done...one more thing. Continuing to poke around, I found I can still install the output module into Bridge, so I installed it into 2017.
How to install Adobe Output Module in Bridge CC 2017
I went ahead and installed it, and it turns out my memory is faulty. There was a web gallery option that had transitions. But, these transitions are based on Flash (deprecated technology). You'd have to modify the .swf file, or recreate the slideshow. If you want a modern slideshow, do it as a PDF. You can create a high-res PDF that doesn't compress your images, or cause you to use detail. If you want to go that route, you can use the PDF button shown below, or just create it via File > Create Multi-Page PDF in Acrobat. I can meet you in the Acrobat forum if you need help.
Fantastic!!   Thanks for all your help.  This is a personal project, so I will be working on it, well armed with your info, this weekend.
Excellent! Glad we could help.
While the bridge output module can generate 11 different style Web Photo Galleries  which will work fine when you upload thet to you web server.  10 of the 11 are flash based.  Which can no longer be preview them on you machine because for sometime now Web browsers will not display Flash Web Photo galleries from your local disk.  You may be able to using chrome I believe there is chrome testing option that will allow local file access.  In the  optional CS5 Plug-in Web Photo Gallery you can generate HTML Web Galleries slide shows.  The Photo Pages refresh the next page in the gallery  after so many seconds and loop back to the first image from the last image.
JJMack
Thanks—I played with it after the question was resolved. When I woke up this morning, I totally believed the Output module was gone for good. Who knew it was still lurking online, just waiting to be reinstalled!
It still around and while I have it installed in mosts of the versions of the bridge I have installed. I did not install it in Bridge CC 2017. For I use CC 2014. I have too many problems using CC 2017.
JJMack
