Printing from adobe Adobe Reader always fails for me. Printing to a physical printer silently does nothing. Printing to a PDF save creates an empty 0B file with the right name.
It used to work, until quite recently.
I use Adobe Reader on Android 6.0.1 on a DTEK60.
I have examined permissions and all seems well. I have reinstalled Reader and no change. I have successfully printed using other apps including Google Drive's PDF viewer.
Happy to hear any suggestions.
Uninstall and reinstall with ARM 15.0........I had same exact problem that cured it. Don't allow it to update until tthey get this fixed.
Adobe Acrobat Reader 15.0.0 (arm) APK Download by Adobe - APKMirror
That release is nearly 2 1/2 years old but for me the print function was working two weeks ago.
Sorry but that is the latest I can find that WORKS........... don't knock it,.... try it,...problem solved for now.............
I offer a solution... and It works........ if you can do better..go for it..........
Ok here's 17.2, it also works.......
For ARM: ftp://ftp.adobe.com/pub/adobe/reader/android/17.x/17.2.0/arm/AdobeReader.apk
For x86: ftp://ftp.adobe.com/pub/adobe/reader/android/17.x/17.2.0/x86/AdobeReader.apk
[Links updated by moderator]
Seems like the recent update to 17.3 is where it went sour..........
I hope Adobe is aware of this issue......and will correct it next update.
The reason I found out is from a friend that was having issues, so I tried it on a totally different phone than his, Problem was same.
All of the net they blame cloud print drivers. I though since it used to work, maybe an older version would work, and that took care of the problem.
I can't get your second apk to work. Looks like not packaged right. First post works great. Thank you.
Adobe does not care. As someone said they are blaming on everyone else. And it's not all devices that have issues. I can use 3 other tablets same as mine e and they work fine. VK810. (got one for each family member. Got tired of fixing or dealing with lag. $50 can't beat it)
My phone works fine. Turbo 2.
Only a few of us that have issues so not enough for adobe to worry about.
I have never printed with it, too. So I download some supported apps. You can search and try.
