All menus on top of app dont work. I can pick tools and it work but when trying to open for example file menu it appear and disappear really fast and do not respond to the mouse clicking.
SO I called Adobbe technical support. They gave me this command "netsh winsock reset" and I run it on hte command prompt and Indesign is working well.
Thanks though for your good intentions.
Have a great day
What version of InDesign? What operating system?
R. 2017 CC
R. Windows 10 64 bits
And in addition to Bob's questions, are you using a secondary monitor?
R. yes
Also, check to see if something is on lying on top of your Escape key (ruling out the obvious first).
R. Done. Nothing on it. I tried other apps and for example I open Photoshop and works ok
Which monitor is the menu misbehaving on? The primary monitor or the secondary monitor? And is that monitor a HiDPI display being scaled through windows 10?
In terms of Windows 10 x64, has it been updated to the so-called “Creators Update” sometime in the last month or two and if so, did InDesign's menus work before then?
- Dov
Hi Dov
It it the try version. Just want to make sure all is ok before paying for it
Have a great day
Are you mixing HiDPI and standard monitors?
Hi Bob
No, I not mixing HiDPI and standard monitors
Any fix for this for MacOS. The same thing is happening to me since I updated to Monterey last night. Can't access ANY menus - just flash and disappear.
Yes!!
I've been through all of the forums and after chatting with Adobe Tech Support, the culprit (on my Mac, with InDesign 16.4 and 17.1) was the system display scaling setting - I changed it from default for monitor to settings -> displays -> scaled -> more space and everything worked. The menus stopped disappearing on the top and right-click contextual menus worked once again.
This was after uninstalling, cleaning up, deleting prefs, multiple times ... such an easy fix.
