When I use the cloning tool I get error message "could not use the clone stamp because the area to clone has not been defined (alt-click to define a source area)
Yes I'm on the right layer, my alt key works in other situations, I'm holding it down while clicking left on mouse, I've tried it on different images, I've uninstalled and reinstalled, I've tried so many things but it's still not working. HELP me please. I need this for my uni work
The Lounge Forum is not for technical help, please provide the name of the program you are using so your message may be moved to the correct program forum... A program would be Photoshop or Dreamweaver or Muse or Premiere Pro or ???
It's regarding photoshop CC
moved to Photoshop forum
Hi Sarah
Can you show a screenshot including your layers panel (with the layer you are using highlighted) and the options bar - with the clone tool selected.
Dave
I don't see the significance of the first screen shot, but on the second screen shot you have an empty layer active (Layer 1) and a smart object underneath (Layer 0), so there is nothing to sample—that's why you are getting the error message. If you want to clone the umbrella, you need to double click the smart object thumbnail to open the .psb file, and then try again.
Or are you trying to clone the bird onto the umbrella photo? In that case, set the sampling point in the bird file, then return to the umbrella file and start painting with the clone tool.
Even on the second screenshot there should be no issue cloning onto that empty layer (Layer 1) as you have the clone tool set to "current and below" so you will pick up the image from below. I do this all the time with smart objects in the layer(s) below.
When you hold the ALT key and click - do you see the cursor change?
I would try the preference reset suggested by BarbBinder. Given that you are in Photoshop, go to Preferences > General and click Reset Preferences on Quit. Then click OK, close and restart Photoshop
Dave
I've done this and now I've lost the ability to use the alt key for enlarging the brush size and for zooming but it still works for other things
My mistake. I though the message was indicating Sarah could not set a sampling point, not that she couldn't paint because it wasn't set in the previous file. Yes, she should be able to paint on the empty layer over the smart object.
So Alt+Right mouse drag left/right is no longer working to change the brush size with a painting tool? For the moment, you can tap [ and ] to decrease/increase the brush size. We can come back to this once cloning is working. So, after deleting prefs, is cloning working?
No it's still not working
Ok. To clarify, you are trying to clone the bird to the umbrella file? Is that correct?
I'm unclear if it is an issue with setting the sampling point or with the Alt key in general.
No sorry the bird image is to show the different ways I've tried. The 2nd one is the image I want to work on, I'm trying to remove dust spots and the wire in the 2nd shot.
I cant (or don't know how correctly) select a sample point at all on any file I've tried.
Yes I've tried both and neither work for this, they do work for other things such as alt-shift-ctrl-k brings up the dialogue box.
I'll try a hard reboot now
No the hard reboot didn't change anything
Ok, you won't be able to clone out the dust spots/wire in the second image because it is a smart object. (And for those sorts of corrections, I would start with the Heading Brush (set to Content aware), and work on a copy of the original layer.)
But sticking with the Clone tool, and assuming that the Alt key works and that perhaps you aren't sure how to clone:
Thanks for this, steps 1,2 & 3 have worked. Once selected cloned stamp, I don't get the error message but the circle doesn't change at all
Sorry I take that back as I wasn't on the clone tool, I still get the error message
Hold the Alt key down and click on the line to well to the right of the purple spot—a bullseye will appear as you set the sampling point. It will disappear when you release the Alt key
This above doesn't happen
If this is happening only on this layer, try creating a new layer and placing the image you are trying to use the Clone tool with on that new layer and try the Clone tool again. Sometimes layers get corrupt and do not work properly.
it happens with all files so isn't just this layer
Can you try this on another computer somewhere?
sadly no, I don't have access to another computer. The alt key works on pretty much everything else except cloning and healing
Have you tried closing Photoshop and holding down the following keys on your keyboard while you re-open the program?
Mac - Command + Option + Shift
Windows - Control + Alt + Shift
Keep the keys held down until you see the following:
Click Yes and then re-open your file and try the Clone tool again.
Please let me know if this does not work.
For some reason I don't get that message. I have reset the tools though
Can you share the document with us?
