RoboHelp 2017 - Indoigo layout - breadcrumbs not working
Aug 01, 2017 Aug 01, 2017
Hi there,
Currently, I'm using an Indigo layout for my project, which builds breadcrumbs pretty well by default. Hovewer, It's not possible to move anywhere around my Help by clicking the breadcrumb links. They look like links, but seem not to be working. For example, clicking Section One in the breadcrumbs area does nothing, while clicking Section One in TOC opens the corresponding default topic for this folder.
Any idea how to fix it?
908
From the image you have shared it looks like you are opening the topic from toc by clicking it. In your case there is a book without link having topics inside it. Section One does not have link to any topic and that is why, clicking it in breadcrumb does nothing and clicking it in toc will expand/close this book.
To check the link of Section One, Go to Table of contents pod.
Select the entry and right-click>properties
Now you can see that there is option to link the book with some topic.
Once you link it with some topic then it will start working.
Let me know if you need any help.
Thanks and Regards,
Surbhi MaheshwariRoboHelp Team
HI Surbhi, unfortunately your assumption is not correct. Section One folder does have a default topic set. Any other ideas how to fix it?
Adobe Employee ,
This case is working correctly at my end. When a book has link then it opens from breadcrumb as well.
Let me know your RH Build number from Help>About RoboHelp
I will investigate and let you know.
Surbhi Maheshwari
It's RoboHelp 2017 (13.0.0.257)
Many thanks! Looking forward to your answer.
Hi there
We need some clarification on this. You said: "Section One folder does have a default topic set"
While sometimes the TOC structure is represented by a folder icon and the items in the TOC may reside in a folder inside your project, I'm unclear on what you are meaning with this. In RoboHelp, you may nominate any HTML Topic page to be the "Default Topic", there is no concept of a default topic for any given folder.
Are you able to clarify what you mean with this?
Thanks... Rick
Hi Rick,
"Section One folder does have a default topic set" - this means that this folder (book) in TOC has a selected Book with Link check box and it has a defined topic that should open when someone clicks Section One in TOC.
Aug 02, 2017 Aug 02, 2017
Hello,
I have same issue as olkkka. It's quite urgent to get it resolved asap. Will there be any follow up on this? Captiv8r surbhi_maheshwari
Thanks heaps!
Adobe Employee ,
This issue is fixed in patch one release of RH 2017.
Follow these steps:
Go to Help> Updates
Update the RoboHelp.  BUild number will be 13.0.1.279
In your project select a new indigo layout from gallery and generate HTML5.
It should work fine.
Let me know how it goes.
Thanks and Regards,
Surbhi Maheshwari
Surbhi,
So it went not quite successful. I followed all the advised steps, however, the issue seems to be not resolved in 13.0.1.279 build.
Also, I noticed that it was not mentioned among the resolved issues: Issues resolved in Adobe RoboHelp (2017 release)
Awaiting your reply.
Could you please follow up on this matter? surbhi_maheshwari​
Thank you
Aug 03, 2017 Aug 03, 2017
Have you tried importing the layout again giving it a new name?
Peter Grainge
www.grainge.org
@petergrainge
Hi Peter,
Yay! Layout renaming did the trick!
Thank you so much for your help!
Marta
It's not so much the renaming as grabbing the corrected layout that shipped in the update. With HTML5, it's usually the case that any fix is in an updated layout and RoboHelp does not automatically update what you are using as that could override any customisation.
See www.grainge.org for RoboHelp and Authoring information
@petergrainge
Adobe Employee ,
I mentioned in the steps to import new layout from gallery.
Glad to know that it worked for you !!
Let us know if you face any issue while using RoboHelp.
Surbhi Maheshwari
RoboHelp Documentation
Download Adobe RoboHelp
