Hi All
I just wanted to check to see if the Adobe Cptivate tool is dependent on the user having flash? We recently ran into an issue where one of our developers flash players were removed and then a very old version was loaded. When he tried to log into Adobe he received an error notification telling him to install the latest version of flash.
I am sure most of you are aware of the issues going around with flash and in our company there has even been talk of potentially removing flash (which they did in fact for about a month) unless Adobe supplies the updates and security fixes more regularly.
My main concern is although we can publish for HTML5, if the actual tool is dependent on flash when authoring, how would we be able to use Captivate if flash is removed?
Please can someone from Adobe respond and let us know.
Carl
Carl, this is a user forum, staff members only occasionally pop in.
I am totally confident that the Adobe Captivate team will be ready when Flash player is removed, have more concerns about companies realizing too late that old courses are no longer playing as expected. I hope you did read this article by Akshay Bharadwaj:
Flash & The Future of Interactive Content for eLearning | eLearning
In the Captivate environment at this moment for normal projects, several Preview methods do use a temporary generated SWF. Probably in a near future this will no longer be the case. Already for responsive projects none of the Preview methods need Flash player, so you shouldn't worry about that. Publishing to exe or to interactive pdf needs Flash as well, have no idea if there will be a replacement or not.
Thank you very much for this reply.
It's given us a lot to think about.
Wanted to add another comment, because there is a lot of misunderstanding about 'Flash will be or is dead', which is not correct. Flash player will be EOL, but Flash itself is very much alive, probably the most important tool for gaming and interactive animtations. The name 'Flash Builder', because of the negative 'sound' since that fruilt company condemned it, has been replaced by Animate CC. You can create Flash output and HTML5 output with Animate CC. Look at this poster:
