Hi guys, As the question says - should I keep my RAW files after I have imported to Lightroom and have them saved as .dng files? I've attached a screenshot of the way my folders look with all files sabved as CR2 (raw) and dng (lightroom).
It seems a excessive way of storing files with two of eveything. Any help would be much appreciated.
Nick
If you ever might use other software than Adobe software on your photos, you need the RAWs. If you're 100% sure -- wait, make that 125% sure -- that you will never need other software, you will always use Adobe software forever and ever until the stars no longer shine, then you don't need to keep your original RAW images.
Another option is to not convert to DNG and just work with your RAWs.
I am curious to know- how you "Saved" the DNG files?
Are you "Exporting" from Lightroom with the option of "DNG"?
If this is the case, then you have no reason to keep the DNG files at all. Your raw CR2 files are the files "in Lightroom", they are the files you see in the Library and Develop views, and MUST NOT be deleted.
(In reality- photo files are NEVER 'in Lightroom', they are always in folders of your computer where Lr knows to look)
The other 'case' is that you used the Adobe DNG converter to make the DNGs from the CR2 files- Yes or No? This needs a different answer.
Hi Wobertc, I'm not a particularly new user to LR having been using it for about 4 years or so. You comment am I exporting from LR into .dng has left me unsure of the process I am using.When I import I get asked for a 'destination' and they end up ther as .dng files. Is there some other way I should be or could be importing? I seem to be doubling up on my files - no wonder I am runnning out of space rapidly. Once again thanks.
As far as I know I'm not using Adobe DNG converter.
Lightroom 5 does not sea my Cannon 80d raw files...i must covert them to DNG first..so here is how i proceed!
( 1) import off Camera Card using using Cannon's DPP4
(a) Store Raw files by Date hierarchy ie (03 04 2018)
(2) Open Adobe DNG Converter and find date stored folder and convert.
(a)DNG moves converted photos to my (Was raw Now DNG) folder.
(3) Open Lightroom, find (Was raw now DNG) folder AND import (Don't Import Suspected Duplicates) checked,
(4) can i now delete photos from (Was raw now DNG) folder???
and does anyone have a faster way of converting raw file for Lightroom other than Upgrading Lightroom???
thanks
Burry
Here is one suggestion. You could use the DNG converter as your downloader. Just choose your camera card as the source and then designate a folder on your hard drive as the destination folder. Then the conversion to DNG can take place as the images are transferred to the folder in one operation.
NO, NO, NO...emphatic NO!
The DNG files are now your 'Original' files and MUST be preserved for Lightroom/Photoshop to access.
Lightroom does not store them somewhere in the catalog.
AND you must have backups of your DNG raw files!
I endorse Jim's suggestion to use the DNG Converter to Download, Convert, and place the converted files in a "Destination" folder. AND this folder will be the permanent storage folder for these photos, with never a need to move them again. But definitely do NOT delete them!!
You will Import them to Lightroom from this folder with the "Add" option.
There are some who advocate routinely and automatically converting everything to DNG. I suppose there is some merit to doing that although I don't do. I personally prefer to work with the original raw (NEF) files from my camera. Unless I find it necessary to round trip to Photoshop, that is the only image I keep on a permanent basis. If I go to Photoshop then there is a TIF file as well. JPEG images are exported when needed, used for their purpose and then deleted. I haven't found any real benefit to converting to DNG, there isn't that much space-saving when comparing to the original NEF. So I prefer not to bother with the conversion process.
Hi jim I am exporting from LR into .dng but I'm stupidly unsure of the process I'm using.When I import I get asked for a 'destination folder' and they end up there as .dng files. Is there some other way I should be or could be importing? Thanks for your help Jim
So, I'm going to modify my original reply, because in your original post, you did not mention the word "Export" anywhere, and the phrase you used "I have imported to Lightroom and have them saved as .dng files" could easily imply that at Import you converted the originals to DNG. As a side comment, it is always helpful to use the Lightroom name of the function ("Export" and not "save") to avoid confusion.
I don't feel there is much reason to export as DNG if you have imported the original RAWs in Lightroom. I'll go further and I would say you don't need to export as DNG, you can export as either JPG or TIF. Or you can do like many people do and not export at all as permanent files, but rather only export the files when you need them outside of Lightroom, and consider the exports as temporary that can be discarded when you are finished using them outside of LR. This is the "least work" option and also the "least disk space" option.
Thanks dj_paige, you're right in what you say and thinking about it I don't need to export as dng at all. Thanks for your help, it's helped clear things up fpr me. Nick
Hi Jin, haha no not ta all - I love Lightroom. when you mentioned about other software I had to think if I would or am likely to use anythng other than Lightroom or Photoshop. I love both programs and can't imagine using something else. From the replys I've had to my original question I now realise I was saving my files as a dng for no reason. Thankfully I now understand inn my workflow there is no reason for that. Thanks for your help.
This is creating COPIES of files, so you will then have both Cr2 and DNG versions.
Do not "Export as DNG"
Some explanations may be helpful
Unless you have reasons to use DNG ** you can simply have your CR2 files referenced in Lightroom. (I won't discuss the debate- Proprietary RAW vs DNG raw)
There are two ways to get your CR2 files shown in the Catalog-
1. From the Camera Card- Import with the "COPY" option and set the DESTINATION folder for the CR2 files storage.
2. From a folder in your computer- Import with the "ADD" option, which leaves the CR2 files exactly in the folder where you put them.
If you want all your files as DNG the methods are different-
1. From the Camera Card- Import with "COPY as DNG" and set the DESTINATION folder for the DNG files storage.
2. From a folder in your computer- Import the CR2 files, then use the Lightroom menu to CONVERT them to DNG.
**(For Lr versions incompatible with a camera proprietary raw file- then the Adobe DNG Converter needs to be used before importing)
Nick, I hope you are making sense of it- don't give up on Lightroom.
Hi wobertc, thanks for takig the time to explain. I now understand what I've been doing and that in my workflow I didn't need to save as dng. Cheers for that and now it's on to understanding smart folders and import presets. 🙂
Thanks for the quick reply - it's left me thinking will I ever use anything other than photoshop?. Cheers.
Would you care to qualify that statement? Do you mean that you don't intend to use Lightroom at all? Or, is Photoshop the only program you will use in addition to Lightroom?
