I have a photo that I have removed the lettering on the wings, I now want to add different text to the wing so that it curves on the wing and looks like it is the same as the text originally on the picture. I have tried using the displace method but the reflection of the white on the wing just distorts the text wrong.
This is the original.
This is the blanked jet.
You're right that the shading on the wings does not lend itself to the displace method. You could make your own shading in a separate file and use that as the displacement map. But I would probably eyeball it with this method:
Looks like we were typing together Barbara - but you were faster and more detailed so you should definitely get the "correct" answer .
At least we came up with the same method!
Dave
Davecm, Thanks for being such a gentleman!
This happens to me a lot that someone else is replying at the same time because the page doesn't refresh as I'm typing. Sometimes my answers are marked correct when I don't deserve it and sometimes they are not marked correct when I do. I guess it all averages out.
Awesome, Thank you so much I will go try this and and let you know how it went.
Hi
You could add your Text layers, convert each to a smart object, then use Transform Distort and Transform Warp to shape the text over the wings.
Dave
Everything worked perfectly, thank you again.
I'll just add that Dave's advice to use Smart Objects in this situation is a must, because if you Transform the type layer and then decide to improve it, the bounding box is still square to the text
Otherwise you get into this situation, which is a mess
The perspective is reduced because of the plane being banked towards the camera, but there is still some foreshortening, and it is is important to match the rectangular bounding box to imaginary (or actual if you draw them in) perspective lines. The upward angle of the wings complicates the true perspective.
But the front to back (from the camera's PoV) is going to be close enough if we rotate it to match the wing, and we have that hand line in front of the aileron to align with.
So you can box the type layer Smart object to align with our perspective lines.
And right click to warp in the curve of the wing. Warping the match the curve of the wing.
Note warping Smart Objects can be a challenge as they don't work the same was as raster layers. I can't say that I have the definitive answer on making do exactly what you want, but you tend to need to use the handles at the opposite end. The big advantage here, is that you can keep going back to it and adjusting, and never loose the original bounding box, so you can get there eventually.
If you look at the wings at the tip there is a couple lines painted on the aircraft they are straight, the same orientation as the letters. What I ended up doing was using that line to make the bounding box curve to that line to get the right curve for the wing, I cannot load the finished picture or I would. We are using it for a future announcement, and would ruin the reveal.
I did use smart object.
Google tells me that this is the BD5 Micro Jet, and it looks like a fun aircraft. If you are involved with its production, then I am seriously envious. Flying such an aircraft through what appears to be Monument Valley, or somewhere similar, must be one heck of a buzz.
It is a BD5J the company I work for was one of the original engineers for this plane Robert Bishop. It is super fun he used to do air shows but has gone into DoD contracting.
You might recognize the plane from James Bond Octopussy, He was also the coars light silver bullet. You cannot fly it if your feet are much bigger than a size 9 US. Our pilots love the flying the lane and I enjoy working around it. I am not sure about posting web addresses here but if it's allowed you can see more at www.smart-1.us.
I mocked up a picture to show how it turned out.
