Processing google weather XML file Information
Oct 29, 2008 Oct 29, 2008
Google weather APi returns an XML file that I would like to process and store content into a database. You can view sample xml file by entering this in your browser .. http://www.google.com/ig/api?weather=chicago
How can I go about retrieveing the xml file and storing into a database ..This is wahat I have so far, let me know how to proceed since this does not work ..
<!--- Set the URL address. --->
<cfset urlAddress=" http://www.google.com/ig/api?weather=chicago">
<cfhttp url="#urladdress#" method="GET" resolveurl="Yes" throwOnError="Yes"/>
<cfset xmlDoc = XmlParse(CFHTTP.FileContent)><!--- THIS DOES NOT RETURN ANY CONTENT????. --->
<!--- Get the array of resource elements, the xmlChildren of the xmlroot. --->
<cfset resources=xmlDoc.xmlroot.xmlChildren>
<cfset numresources=ArrayLen(resources)>
<cfloop index="i" from="1" to="#numresources#">
<cfset item=resources >
<cfoutput>
<strong><a href=#item.url.xmltext#>#item.title.xmltext#</strong></a><br>
<strong>Author</strong>  #item.author.xmltext#<br>
<strong>Applies to these products</strong><br>
<cfloop index="i" from="4" to="#arraylen(item.xmlChildren)#">
#item.xmlChildren
.xmlAttributes.Name#<br>
</cfloop>
<br>
</cfoutput>
</cfloop>
Advanced techniques
998
> CONTENT????. --->
It does for me! Have you confirmed that the ColdFusion server can
access the URL.
<cfoutput>#xmlDoc #</cfouput>
Does this return content for anyone elsse ??
Put <cfoutput>#cfhttp.filecontent#</cfoutput> before the <cfset...> line
and see what is actually being returned from your request.
It might be an error message or some other content that is not XML formated.
This returns a blank as well ..
Then for some reason your server is not getting through to Google's
server of their response is not getting back to yours.
All I can say is it worked correctly and repeatedly so from mine.
Oct 30, 2008 Oct 30, 2008
I am on a developement machine and using "localhost".
I can access the url fine from the browser and get the results on the browser. That verifies two way communcation to return xml results. Any other ideas
bemall wrote:
> That verifies two way communication to return xml results. Any other ideas
That verifies that *you* have two way communication.
ColdFusion, even running on localhost, does not run as *you*, unless you
have told it to. By default it runs as 'localSystem' on Windows, on
Unix it will run under the user defined at install time.
It is quite possible for there to be cooperate domain policies that
allow you to access the internet, but not a generic 'localSystem' user.
One way to test this would be to configure the ColdFusion service|daemon
to run under your user name and password. Not an ideal, long term
solution, but a good test.
This makes a lot of assumptions about your details. This is a problem
with your system and your network connections. Those are the people you
are going to need to be working with to find out why this is not working.
Documentation
