Hey fellas,
Does someone knows how to fix this issue?
I've set two keyframes so the image will go from top to bottom. Problem is - the image goes lower than I've set and the returns to the second keyframe I've set.
I looked at the graph editor and it shows this line:
I have no idea why it does so.
Someone knows how to fix this bug?
Cheers,
Ori.
Alright, I've found the answer -
You just need to select the 'problematic' key frames, right-click on one of them, press "Keyframe Interpolation", and over there choose "Spatial Interpolation: Linear".
Convert those keyframes to Hold Keyframes to avoid interpolation
