Issue creating a new refined list in a listbox
Aug 02, 2017 Aug 02, 2017
I have created a table using the following code from "ScriptUI for Dummies".
entry.onChanging = function ()
var temp = entry.text,
tempArray = [];
for (var i = 0; i < array.length; i++)
if (array.toLowerCase().indexOf (temp) == 0)
tempArray.push (array);
if (tempArray.length > 0)
// Create the new list with the same bounds as the one it will replace
tempList = w.add ("listbox", list.bounds, tempArray, {scrolling: true});
w.remove(list);
list = tempList;
list.selection = 0;
} // entry.onChanging
It works in CC2014, but in CC2017 it seems to mess up as soon as I change the edittext box.
From what I can see, the issue is on line 11 (above), where list.bounds seems to cause an issue, however I also believe the issue may be elsewhere.
Am I missing something?
Thanks in advance for your help.
Actions and scripting
588
Community Expert , Aug 03, 2017 Aug 03, 2017
I adapted your code and my code to a new example. I still used your part where you search the original array and push that info into the tempArray. But rather than replacing the listbox, I just removed it's items and replaced them with the ones in the tempArray.
#target photoshop
var w = new Window('dialog','listbox text')
var list = ['one','two','three']
var list2 = ['four','five','six']
var entry = w.add('edittext',undefined,'');
entry.size = [200,20];
w.listBx = w.add('listbox',undefined,list,{numbe
Adobe
When you remove the listbox items, you have to replace them in the listbox, not just the array. Here's an example:
#target photoshop
var dlg = new Window('dialog','listbox text')
var list = ['one','two','three']//original list
var list2 = ['four','five','six']//new list
dlg.btn = dlg.add('button',undefined,'reset')
dlg.listBx = dlg.add('listbox',undefined,list,{numberOfColumns: 1});
dlg.btn.onClick = function(){
    dlg.listBx.removeAll();
    for(var i=0;i<list2.length;i++){
        dlg.listBx.add('item',list2)//adds the array items back to the listbox
dlg.show()
Hi Chuck,
That replaces the list. I want to update the list with items I have.
So for example. When I type "Ma" - it will only show options that start with "ma"
My end goal is to create a listbox that will list a large number of items that I can search easily with an edittext search bar.
Would that be possible in CC2017?
That would be the same sort of thing. You would have to use the text box, then loop through your original array doing a search for entries that match, push those to your temp array, then replace each item as I showed. You will want to leave the original array untouched, so that you could reset the listbox.
Cheers Chuck, I am afraid I am not very comfortable with Javascript yet. I am primarily a retoucher.
Would you mind giving me an example that includes an 'edittext' search bar so I can see it in action.
I have tried changing a few things to follow your example, but I am not having any luck.
Here is a sample of my code:
The actual code is much longer, so I have cleaned it to just show the important areas
#target Photoshop
picked = type_ahead ([ 'Apple','Apricot','Avocado','Banana','Bilberry','Blackberry','Blackcurrant','Blueberry','Boysenberry','Currant','Cherry','Cherimoya','Cloudberry','Coconut','Cranberry','Cucumber','Custard apple','Damson','Date','Durian','Elderberry','Feijoa','Goji berry','Gooseberry','Raisin','Guava','Honeyberry'
,'Huckleberry','Jabuticaba','Jackfruit','Jambul','Jujube','Juniper berry','Kiwifruit','Kumquat','Lemon','Loquat','Longan','Lychee','Mango','Marionberry','Melon','Cantaloupe','Honeydew','Watermelon','Mulberry','Nectarine','Nance','Olive','Orange','Blood orange','Clementine'
,'Mandarine','Tangerine','Papaya','Peach','Pear','Physalis','Plantain','Plum','Prune','Pineapple','Plumcot','Pomegranate','Pomelo','Quince','Raspberry','Salmonberry','Redcurrant','Salal berry','Salak','Soursop','Star fruit','Solanum quitoense','Strawberry','Tamarillo','Tamarind','Ugli fruit'
,'Yuzu']);
function type_ahead (fruits) {
var w = new Window ('dialog {text: "fruits", alignChildren: "fill"}', undefined, undefined, {closeButton: true});
var entry = w.add ('edittext {active: true}')
var list = w.add ('listbox', [0, 0, 120, 500], fruits);
list.selection = 0;
entry.onChanging = function () {
// entry changing logs fine
var temp = this.text,
tempArray = [];
for (var i = 0; i < fruits.length; i++) {
if (fruits.toLowerCase().search (temp) == 0) {
tempArray.push (fruits);
// upper and lower case changes log fine
} //lowercase
else if (fruits.toUpperCase().search (temp) == 0) {
} //uppercase
var tempList = w.add ('listbox', list.bounds, tempArray);
w.remove(list);
list = tempList;
list.selection = 0;
} // templlist
} //for
}// entry.onChanging = function () {
ListItem.add
var btn = w.add ('button', undefined, 'OK', {name: 'ok'})
list.onDoubleClick=function(){
if (list.selected){
// do something here
} //if (list.selected){
w.close();
}// list.onDoubleClick=function(){
if (w.show () != 2){
     var clicked = list.selection.text
alert(clicked);
} // if (w.show () != 2){
w.close();
} //function type_ahead (fruits) {
Many Thanks in advance!
#target photoshop
w.listBx = w.add('listbox',undefined,list,{numberOfColumns: 1,scrolling: true});
tempArray = [];
for (var i = 0; i < list.length; i++)
if (list.toLowerCase().indexOf (temp) == 0)
tempArray.push (list);
// Create the new listBx with the same bounds as the one it will replace
w.listBx.removeAll()
for (var i=0;i<tempArray.length;i++){
    w.listBx.add('item',tempArray)
w.listBx.selection = 0;
w.show()
Many thanks Chuck, this worked.
Good!
